Author Topic: Urgent help required. Mk3 gti door trim problem  (Read 1287 times)
Offline arran.concept
  • Yellow Colour Concept
« on: 21 October 2012, 14:49 »
Having bother with refitting my door trim. I have 5 clips all on and lined up but doesn't seem to go far enough into holes to sit nice and flush :( help can't see how to resolve this problem.
Offline Screech16v
  • MK3 20vt AGU
Re: Urgent help required. Mk3 gti door trim problem
« Reply #1 on: 21 October 2012, 14:51 »
if you mean around the sides and bottom then may be one is out of line to the hole as they can move about a bit.
Offline kirk
« Reply #2 on: 21 October 2012, 14:57 »
From memory there should be 2 different size clips, the 2 outer clips should have smaller bits that go in the hole and the middle three have a bigger bit sticking out to go in the hole. Hope that makes sense
Offline kempie
  • where would we be without duct tape?
« Reply #3 on: 21 October 2012, 16:27 »
3 or 5dr?
front or back?
there are 2 different clips that have different depths i think its the rear ones that have all shallow clips and the front has all but 2 deep clips
sounds like you have all deep clips where you need some shallow ones
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 22 October 2012, 15:09 »
Sounds right ^^^
