Author Topic: Moisture in car???  (Read 1121 times)
Offline seanyd
Moisture in car???
« on: 21 October 2012, 00:24 »
Hi guys I've been in Spain for a week come back and my carpet and headlining are soaked through any ideas what it could be thanks guys
Offline tweed
Re: Moisture in car???
« Reply #1 on: 21 October 2012, 00:30 »
My guess is sunroof. And if you don't have one, check ariel mount.
Offline seanyd
« Reply #2 on: 21 October 2012, 00:31 »
Uh thought it would be sunroof guess I should get a new seal
Offline GolfGL
« Reply #3 on: 21 October 2012, 11:18 »
Yes the sunroof needs a seal but in the sun roof are drainage gutters if these are blocked it can drip into the car. open the sun roof and you can see the two holes at the front. the two rears are slightly more concealed. by the door hinges you can see the exit of the drainage tubes which look like a snipped piece of rubber tube, clean these as mine were stuffed with mud and grit then flush with boiling water by pouring it into the sunroof gutters. the rear drainage tubes are hidden under the bumper behind the wheel so i just left the water to hopefully clear them. you should notice that on all 4 corners water should drip out at the same speed. also get your carpets up as the sound deadining while rot and rust your floor!
Adam
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
