Author Topic: clutch problem  (Read 1255 times)
Offline tiredtracey
clutch problem
« on: 19 October 2012, 21:50 »
Hi I think I know the answer to this question but I'm gonna throw it out here, just in case I've overlooked something.
I've just completed an engine conversion on my mk2 golf gti, I've put a 2ltr AGG bottom end on my PB head and using my mk2 gearbox, I've left the mk3 clutch on the bottom end, as the bloke said it was a goodun  got the engine running today with no problems running great  only thing is when I depress the clutch I get an awful squealing noise, went i put it in gear with the engine off and start the engine the wheels dont spin (on axle stands) so I'm guessing its not engaging
any suggestions or is it a new clutch? if so do i buy one for a mk2 or 3 ?
thanks
T
Offline molegti
Re: clutch problem
« Reply #1 on: 20 October 2012, 07:57 »
Might be worth adjusting the linkages before looking at the clutch.
Offline Jimmyrallye
  • 20vt goodness
Re: clutch problem
« Reply #2 on: 20 October 2012, 08:26 »
This ^ ive bolted my my 8v box on my 20vt conversion and my gear linkages all over the show!! Ive bought a mk3 abf gearbox and cables for a hydro conversion now
Offline tiredtracey
Re: clutch problem
« Reply #3 on: 21 October 2012, 19:38 »
are they adjustable as I cant see any adjustment areas. I was wandering if the mk3 had more or less teeth that the mk2 thus its not meshing up?  :undecided:
