Author Topic: Will a bora gear shifter and gaitor fit in a mk3 golf ?  (Read 3933 times)
Offline Itteh
  • Built Not Bought
Does any1 know if a bora gear shifter and gaitor will fit in a mk3 golf ? i prefer the bora one its smaller, as mine is quite high, and old owner or older than him has an aftermarket gear knob put on... not really fond of it tbh........
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: Will a bora gear shifter and gaitor fit in a mk3 golf ?
« Reply #1 on: 18 October 2012, 22:00 »
i run a mk4 shifter in my S3 mule
i also run a modified Mk4 gearbox (02J)
to get the shifter to work requires quite a bit of modifying as its a bigger unit.. not a simple mod anyhow.
you will also need the 02J tower for your 02A gearbox so the cables will join as its a different set up to the crappy mk3 one
the height of the stick tho, you will find when its in the mk3 its much higher the the original mk3 item, to get round this i cut loads off the shaft and ended up with it like this
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline murraymint
« Reply #2 on: 18 October 2012, 22:05 »
Still cool Kells, but I think he mend just the gear knob and gaitor, not  the whole shift setup  :undecided:
If so then it's an easy fit, jus cut the gear stick down a little bit, the fit the gear knob with a jubilee clip
josh
Offline Itteh
  • Built Not Bought
« Reply #3 on: 18 October 2012, 22:11 »
is that it? okay am going to sound like a retard, but what should i use to cut the shifter rod ?
Offline murraymint
« Reply #4 on: 18 October 2012, 22:16 »
Hack saw,
josh
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 18 October 2012, 22:20 »
The best way to shorten it is to run a die down the original thread and continue it down the shaft to where is required and then cut the surplus shaft off with a pipe cutter. Much cleaner, easier and accurate.
edit: This said aren't mk4 Golf's and Bora shafts threadless?
« Last Edit: 18 October 2012, 22:22 by thai-wronghorse »
« Reply #6 on: 18 October 2012, 22:23 »
Brad - Is that centre console rubber mat from a mk3.5 cabrio?
Offline murraymint
« Reply #7 on: 18 October 2012, 22:31 »
Yh, hence jubilee clip  :afro:
josh
Offline Itteh
  • Built Not Bought
« Reply #8 on: 18 October 2012, 22:36 »
thats confused the hell outa me, simple english ? like whats a die ? surplus shaft ?
« Last Edit: 19 October 2012, 00:56 by Itteh »
« Reply #9 on: 18 October 2012, 23:25 »
Yeah I used a tiny jubilee clip on my modified mk4 gear knob (blue plastic retainer chopped down and core drilled out deeper so it didn't scrape against the roof lining)  :wink:
