Author Topic: Electrical problems - windows & sunroof  (Read 999 times)
Offline technics100
« on: 18 October 2012, 14:47 »
I have a number of electrical niggles with the GTi..
1. Sunroof works intermittently, I changed the switch and it's doing the same thing, sometimes it works, sometimes it won't and I have to shut it with the winder.  I get the occasional click from it when pressing the switch.  motor? guides? switch?  sometimes the buttons are lit, sometimes not, is it a wiring issue?
2.  The electric windows - drivers side works, pass side goes down but not up (goes up fine using the remote) - switches broken?  Rear pass was working but has stopped, rear drivers doesn't work.  I pulled the rubber boot back at each door and wiring looks ok..  Anything to check?
1995 Twilight Voilet Mk3 GTi 16V 5 door
