Author Topic: do i have dydraulic tappets or non hydraulic ones?  (Read 1927 times)
Offline stainesy
« on: 17 October 2012, 20:00 »
what i want to no is does my 1985 1.6 jetta have tappets or hydraulic tappets? its a tiny bit tappy but not really noticable but im abit of a perfectionist so was going to get the feeler gauges out and give them a tighten up but before i other taking it all apart thought i would find out if i can or not.
Offline danny_p
Re: do i have dydraulic tappets or non hydraulic ones?
« Reply #1 on: 18 October 2012, 23:32 »
probaly shims   take the rocker cover off  if it's "missing a bearing" there hydralic
all the VW's have gone bar 1.
Offline Gambit
« Reply #2 on: 19 October 2012, 09:26 »
picture paints a thousand words for ya
Hydraulic head will have the following bearing caps - you can see where one is seemingly missing
Offline stainesy
« Reply #3 on: 20 October 2012, 10:45 »
Ok cheers everybody. So does anybody actually no if a 1985 1.6 had hydraulic tapers or not then?  :grin:
Offline clipperjay
« Reply #4 on: 20 October 2012, 12:07 »
For us to know you to find out  :laugh:
get the spanners out  :grin:
Offline stainesy
« Reply #5 on: 20 October 2012, 17:39 »
Well the point of this thread was to ask what it had so I could adjust tappets if it had any. If it don't I wpnt bother taking it all apart and buying a new gasket as if I can't.
Just shined a tourch inside the oil filler hole and its over head cam so nothing to adjust. Will just stick some thicker oil in instead.
Offline danny_p
« Reply #6 on: 20 October 2012, 23:45 »
before you start getting stropy  if you had provided more infomation you would have got a more accurate answer.
1985 is a change over year so chould have ether, may not even have original motor  can usualy tell from a photo of the frount of engine block.   and as for adjusting them if they are solid lifters  yiu have to take it right apart to even get at the shims
Offline stainesy
« Reply #7 on: 22 October 2012, 13:02 »
stroppy?  :grin: :grin:
i have already answered my own question tbh it has over head cam so its not the rocker setup i thought it was. so i will just try some thicker oil :wink:
Offline danny_p
« Reply #8 on: 23 October 2012, 00:02 »
they are all OHC  engines,   thats why adjusting the solid lifters is a twerp.   you have to take the lifters out to change the shims,  that means removeing the cam
