Author Topic: wierd MK1 problem  (Read 2333 times)
Offline podges
wierd MK1 problem
« on: 07 October 2003, 12:28 »
Hello people
wicked site by the way...wondered if you could help a pissed off MK1 1986 GTI cabby owner:
my car sputters like f**k when you turn it over cold...I have to leave the key on 'fire' for around a minute to start it! then the whineing started in the back...this is intermitent and the car (which formerly worked fine when eventually warm) now stalls and cuts out regually......
I need it to commute and have little money so im seeking  a budget solution..
any of you had same or simular problems?
Offline AdamB
  • The Perfect Storm
Re:wierd MK1 problem
« Reply #1 on: 07 October 2003, 12:44 »
My Cab splutters a bit on start up bit runs sweet as a nut (are nuts sweet?)after a couple of minutes. It's almost as if the automatic choke is not doing its job. As it's not a real problem and hasn't manifested into anything worse, I've left it.
« Last Edit: 07 October 2003, 12:45 by AdamB »
I don't own this anymore - I just can't be arsed to change the picture
Offline richandhazel
« Reply #2 on: 07 October 2003, 12:59 »
If you have whining coming from the back of the car then I would suggest your fuel pump is on its way out. Try removing the supply pipe and having a look at the inlet strainer. It may be that it is semi blocked making the pump work harder.
golfvr6
« Reply #3 on: 07 October 2003, 17:24 »
I totally agree with Rich, the whining on the back must be the fuel pump. As for your car Adam, your cold start valve is probably a bit suss if the car splutters from cold.
Offline AdamB
  • The Perfect Storm
« Reply #4 on: 07 October 2003, 17:40 »
Is it a big job to fix? I've never had to do it before ???
golfvr6
« Reply #5 on: 07 October 2003, 21:40 »
Look for the fifth injector mounted on the inlet manifold.
Offline podges
« Reply #6 on: 08 October 2003, 12:23 »
thanks guys the mechanic I know is gonna look at the pump - ?185...downer.
But shes still better that my previous ride  - a deisel escort estate thats for sure..(encore!)
