Author Topic: aug boost pipes and t.i.p  (Read 1059 times)
Offline cooki
  • 1.8T AUM
« on: 16 October 2012, 08:17 »
whats the difference between the AUG and AUM golf engines.
would a T.I.P and silicone boost hoses from an AUG fit my AUM at all.or more importantly what might not fit my AUM as i would take the hit and buy them if the t.i.p fitted but a few boost pipes wouldnt or something.
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline AD1.8T
Re: aug boost pipes and t.i.p
« Reply #1 on: 16 October 2012, 10:32 »
If you mean AGU then the boost pipes are the same but a hole in the tip will need plugging
If you mean AUQ then everythings the same
Offline cooki
  • 1.8T AUM
« Reply #2 on: 16 October 2012, 12:43 »
AGU i ment mate sory.
tip was off a ko3 turbo on a agu engine.
guessing my AUM is a ko3 poss ko3s so should fin in theory but will need 1 pipe on it blocking off yes??
Offline rio_gti
« Reply #3 on: 16 October 2012, 12:58 »
i got a tip on mine and had to block one of the pipes, think the only other dofference is the dv and hockey puck are the other way round
Offline cooki
  • 1.8T AUM
« Reply #4 on: 16 October 2012, 14:59 »
tar for the info rio mate.cheers.
is thst a 5 piece boost pipe kit u got fitted in ur sig aswell yes??if i had my engine cover on i would prob only see the large 1 at the front on the inlet manifold wouldnt i lol.
Offline rio_gti
« Reply #5 on: 16 October 2012, 16:14 »
no probs... yeah it is, and yeah you would!!
i mainly got them as the performance increase thou not just cos they're pretty  :kiss:
