Author Topic: FMIC benifits  (Read 1071 times)
Offline dstv
FMIC benifits
« on: 14 October 2012, 21:20 »
Hi guys
could someone tell me what benefits a fmic would give the car in performance.?
Im currently running AGU remapped and ko3s turbo. and soon will have the option of either buying a fmic or the 3" exhaust that some people on here have bought already. So basically which one first?
But some input will be great.
Thanks
Eugene
2000 GTI 1.8t AGU, neuspeed airfilter,Forge 007 dv, R-tech stage 1 remap, Silicone TIP,3" exhaust system, K03s turbo and a empty wallet.
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: FMIC benifits
« Reply #1 on: 14 October 2012, 21:33 »
Cooler and denser air to then shove into your engine which makes it go bang bang better.
A larger IC gives the air a better opportunity to cool down before it goes into your engine which has a positive affect on combustion.
Or something like that  :grin:
But a large IC will increase turbo lag...
Offline littco
Re: FMIC benifits
« Reply #2 on: 14 October 2012, 21:50 »
Nearly.
Lower IATs from the larger intercooler allows for more timing before knock is encountered. More timing = more power/torque. Can also help as will be more free flowing, bigger pipe work etc thus more air flow = more power/bhp.
On a freezing cold day it's not that much benefit but comes into its own on hot days or after cars been running a while and engine/pipe work /air is warmer. Will Definately make a difference with a remap as higher psi boost = more compression in the air which means warm charge air.
Considering prices of an fmic its a win win, providing you don't make it stick out and look Chavy!
Offline scarr89
Re: FMIC benifits
« Reply #3 on: 14 October 2012, 22:01 »
Nearly.
Jesus Littco, I could have gone into that much detail if I wanted...I was just being simple  :whistle:
 :grin:
Offline Chris.
Re: FMIC benifits
« Reply #4 on: 15 October 2012, 00:00 »
Current spec would help.
Personally id be tempted by the downpipe first at that makes the turbo 'breathe' a lot better.
Click For Build Thread
Offline paultownsend
Re: FMIC benifits
« Reply #5 on: 15 October 2012, 10:39 »
im still running the OE SMIC
i have done the inner arch liner mod, taken off the under bonnet fabric and also made a similar size hole in the grille/slam panel like the passenger side. (that the airbox/intake uses).  This flows cold air directly on to the TB/intake manifold.
In traffic the intercooler and intake manifold do get hot. But a quick blast up the road soon makes then cool again.
When my car was getting mapped i was very concerned about heat. Every run was giving less power.
On the Dyno there is inevitable heat soak. But, a HUGE fan just can not replicate a 1.3 tonne lump of metal and plastic moving through the air at 50mph. When you get going it all cools down again.
These are free little mods which have made a small difference.
As soon as i see a mk4 using a normal bumper and a 'wellycooler' behind it il be straight on ebay. I just cant stand seeing the I/C pipes
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: FMIC benifits
« Reply #6 on: 15 October 2012, 12:27 »
FMIC would be the last thing I'd fit before mapping
Offline shaft69
Re: FMIC benifits
« Reply #7 on: 15 October 2012, 12:58 »
personally if get top quality smic be fine with ko3s, if start running big turbo then yes fmic. As said many times before my smic was spot on even on hot day on rollers for 2hrs after about 12 runs. newsouth intake gaskets are big help too. I got mine from my nephew had with APR stage3+ gt2871r turbo he's in Florida he said no heat soak on roasting hot day on rollers. went gt35 and then fmic was fitted, each to there own tho.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
