Golf mk4
Wazzzer
mfd display
Topic: mfd display (Read 1236 times)
cubz
mfd display
14 October 2012, 17:55 »
my mfd on my anni has been fading slowly over the time iv owned it and recently its not visable at all!!
anyone know how to fix this or do i need to replace it?
Build thread-
http://www.golfgtiforum.co.uk/index.php?topic=231212.0
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: mfd display
14 October 2012, 18:11 »
you'll need some immo3 clocks and someone to code them in for you
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
Golf_GT_TDI
2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: mfd display
14 October 2012, 18:16 »
Option 1: buy a replacement cluster and have it coded in.
Option 2: have your exisiting cluster repaired, you need a new LCD.. VDO make them I believe and there is a chap on ebay who can fit a new LCD for you, maybe send him a message?
http://www.ebay.co.uk/sch/m.html?_odkw=&item=261105809531&pt=UK_CarsParts_Vehicles_CarParts_SM&_osacat=0&hash=item3ccb1e787b&_ssn=allsortsuk2009&_trksid=p2046732.m570.l1313&_nkw=repair&_sacat=0&_from=R40
I've suggested the repair option because you mention you have an Anniversary so the cluster in those is worth having the LCD repaired because they are not your normal standard Golf cluster that is available cheaply.
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: mfd display
14 October 2012, 19:38 »
If you just get a set of VDO immo3 clocks everything else can be swapped over to make them the same as Anni clocks (front with rings, foils needles)
Last Edit: 14 October 2012, 22:22 by Wazzzer
Golf_GT_TDI
Re: mfd display
14 October 2012, 21:08 »
That too, good point
cubz
Re: mfd display
15 October 2012, 19:56 »
thanks for replys, looks liek ill live with it for a wee while yet!! will get it sorted once golf is off the road next year sometime,
seems like all the small jobs are building up and will cost em a fortune to fix!
Build thread-
Golf mk4
Wazzzer
mfd display
