Author Topic: MK4 radiator fan staying on and running battery flat  (Read 987 times)
Offline sparky2010
« on: 14 October 2012, 08:50 »
Hu
I have read severals posts on this and have tried replacing the thermo sensor, fan controller module and checked all the fuses.
The problem is that after switching off the engine, even only if it's been on for a minute, the rad fan stays on continuiosly until it runs the battery runs flat.
Any ideas! Thanks
Offline vii-cks
Re: MK4 radiator fan staying on and running battery flat
« Reply #1 on: 14 October 2012, 11:22 »
Do you mean the rad fan switch in the side of the rad? These are quite common? There are fuses on top of the battery, are they all okay?
Your thermostat isnt stuck shut is it and therefore the fan is doing it's usual job? Does car stay at 90?
Offline sparky2010
« Reply #2 on: 18 October 2012, 22:03 »
Hi
I have just changed the fan switch and checked all the fuses on top of the battery and it's all ok.
The fan starts even before I start the engine, when I turn the key to the first position the fans on the drivers side starts straight away?
Any ideas?
Offline james2
  • No scammers please.
« Reply #3 on: 18 October 2012, 23:56 »
Put your aircon on econ mode. I know theres some kind of fuse that goes . But econ fixed mine. That was my first fault and how i got on this site.  :laugh:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
