Author Topic: anything to get my 8V throttle respond much better ?  (Read 1432 times)
Offline Itteh
  • Built Not Bought
« on: 13 October 2012, 19:57 »
anything to get my 8V throttle to respond much better ? de-cat? exhaust ?
Offline tweed
Re: anything to get my 8V throttle respond much better ?
« Reply #1 on: 13 October 2012, 20:02 »
Light flywheel
Offline Itteh
  • Built Not Bought
« Reply #2 on: 13 October 2012, 20:06 »
Cost ££££££ ??
Offline tweed
« Reply #3 on: 13 October 2012, 20:33 »
About the same as a new de cat pipe
Offline trog_nfs
« Reply #4 on: 14 October 2012, 12:02 »
Check the tension on the throttle cable, and clean absolutely everything.
I took most of my intake apart to clean and paint. I discovered that the throttle cable had a ton of slack in it, meaning there was a bit of squidge before getting any movement in the throttle. Plus now I can get full throttle.
Its always worth getting the standard parts working to the best of their ability before trying to bolt on spankly go fast bits.
VW BUSH
« Reply #5 on: 14 October 2012, 13:20 »
I would not say the 8v has poor throttle response just no puff in the higher rev range.
In fact throttle response and initial torque is about all its got :grin:
It is likely you have a fault somewhere or are used to something lighter with a lot more power :grin:
Do you have a flat spot at around 3.5k?
Is the timing correct?
Is everything clean?
Have you got a cone filter sucking in warm air?
Lots of basic things make an 8v drive like a stricken trawler, best to be sure its all working before you go modding.
And I think 99% would agree the only thing to do for instant power in a Mk3 is to put 20vt engine in it.
