Author Topic: Exhaust tip diameters  (Read 6479 times)
Offline ErikGTI
Re: Exhaust tip diameters
« Reply #30 on: 02 December 2012, 12:55 »
I do not get the adjustable bit...
My new exhaust tips were first measured, sawed and fitted with a few weldings ...after a final look I approved (same protusion as the original ones) and with the final welding they were mounted in place with a small metal colar.
I'LL BEAT YOU TO THE BBC STUDIO........
Offline wigit
« Reply #31 on: 02 December 2012, 13:00 »
The Milltek is a modular design so the tips fit over the pipe and bolt on allowing you to set how far you want them to stick out, the Milltek grows a couple of centimetres when warm
Offline ErikGTI
« Reply #32 on: 02 December 2012, 13:04 »
But surely when they are finally adjusted they need to be welded otherwise they will be moving about in the future due to hot/cold...besides the practical reason I personally do not like a bolted look....a bit Halford-style  :evil:
Offline wigit
« Reply #33 on: 02 December 2012, 13:07 »
The Milltek has some really nicely engineered spring clips that are engineered to expand/contract
Offline ErikGTI
« Reply #34 on: 02 December 2012, 13:31 »
Okay did not know that...anyway they are the nicest tips around so quality should be top notch I expect  :wink:
