Author Topic: size of k03 outlet for silicone connector  (Read 4206 times)
Offline rio_gti
« on: 11 October 2012, 14:38 »
can anyone tell me i have forgotten and i cant find it anywhere!!!
its for the reducing bend to 63mm cheers  :smiley:
Offline Dalo Harkin
Re: size of k03 outlet for silicone connector
« Reply #1 on: 11 October 2012, 14:42 »
pretty sure its 54mm
Offline rio_gti
« Reply #2 on: 11 October 2012, 15:33 »
only link on the bay shop is 43mm x 51mm will this be ok??   :undecided:
Offline Dalo Harkin
« Reply #3 on: 11 October 2012, 15:48 »
2" so 50mm, 51mm will be a squeeze but better than a wizards sleeve  :grin:
Offline rio_gti
« Reply #4 on: 11 October 2012, 16:09 »
Cheers Dalo, and i too prefer a virgin to a sl4g  :wink:
ORDERED!!!!  :evil:
Offline Chris#101
« Reply #5 on: 11 October 2012, 19:10 »
sorry to break it to you but the k03s outlet is 45mm :undecided:. So if your running 2.5" pipe work you need 45mm-63mm reduce
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline rio_gti
« Reply #6 on: 11 October 2012, 19:17 »
 :cry:
so how did you do it as ash dont have that on a bend?  :undecided:
Offline Chris#101
« Reply #7 on: 11 October 2012, 19:35 »
I had to get one of these
Link: http://www.ebay.co.uk/itm/SiliconHoses-com-Straight-Silicone-Reducer-Reducing-Hoses-BLUE-BLACK-L-XL-/280905217243?var=
Then I brought an alli 63mm 100mm length joiner to link it to the silicone 90* bend :smiley:
« Last Edit: 11 October 2012, 19:43 by Chris#101 »
Offline rio_gti
« Reply #8 on: 11 October 2012, 20:02 »
k03 outlet
k04 outlet
so when u say 45mm is this the size without the bead so the silicone pipe is tight down on shaft and has to stretch over the bead??
also i would think that welding the k03 outlet would further restrict the boosted air so is there not another way to make this an 'OEM' fit?
and if i have to do it the way you said then it is a good job i found this in a garage!!
