Author Topic: 97 8v GTI gear selection problem  (Read 1458 times)
Offline thomson07
« on: 10 October 2012, 16:46 »
Hi All.
Im having real trouble selecting 1st and reverse gear. The previous owner fitted a new clutch so im hoping its just the cable that needs replaced ?
Anyhoo, any very rough ideas as to how much a independent might charge to replace the cable ?
I simply dont have the time to do it myself.
Ta
Offline harlemex
Re: 97 8v GTI gear selection problem
« Reply #1 on: 11 October 2012, 14:39 »
Its more likely to be gear linkage.
Offline GolfGL
« Reply #2 on: 11 October 2012, 18:01 »
check the linkage is tight and then fiddle around with the adjuster on the gear lever. worked for me but i also refreshed the linkage and found it had been poorly fitted at some point in the cars history.
Adam
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline thomson07
« Reply #3 on: 11 October 2012, 23:15 »
Will give it a try , thanks folks
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 12 October 2012, 13:21 »
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline GolfGL
« Reply #5 on: 12 October 2012, 13:30 »
the tool probably makes it easier but i wouldnt say essential as its a fairly simple mechanism that you can sort out with trial and error adjusting till everything works as it should
