Author Topic: Changing rear shocker  (Read 2037 times)
Offline Willo
« on: 09 October 2012, 16:43 »
Will I be needing spring compressor to do this job ??
Offline Callum_K
Re: Changing rear shocker
« Reply #1 on: 09 October 2012, 18:44 »
Nope not for the rear I've found. The springs aren't under much tension. Easy job. :)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 09 October 2012, 18:44 »
No. Front struts only.
Offline Willo
« Reply #3 on: 09 October 2012, 22:00 »
So a definite no then can ya give me a brief summary of the process please
Offline Callum_K
« Reply #4 on: 10 October 2012, 11:09 »
It's pretty easy.
1)Jack up rear and support on axle stands. Remove wheel
2)In the boot, put seat backs down to enable easy access, and remove any plastic trim pieces so you can get to the top mount. Remove top nut, washers, rubber mount etc. Think it's 17 or 18mm off the top of my head. Remember how it all goes on!
3) Remove bolts at the bottom of the shock after soaking in WD40 as they are most likely rusted tight. This is deffo 18mm. You can now remove the shock.
4) To strip the shock, it' just a case of removing the top nut. The spring isn't under much tension, you can compress it by hand. Then remove the spring plate, washer, bump stop etc etc.
Reverse for reassembly. Attach the shock at the bottom first then use a trolley jack to lift it in to place. If you're replacing a shock, replace the rubber mounts as well as they're most likely worn, and cheap as chips.
Offline Willo
« Reply #6 on: 10 October 2012, 14:36 »
Says rear axle upper in mounting position
Offline madmanmart
« Reply #7 on: 10 October 2012, 19:12 »
It's pretty easy.
As above, although both mounts are 17mm  :wink:
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline Willo
« Reply #8 on: 10 October 2012, 20:32 »
Are they the right ones I've put in the link above for the rubber mounts please
Offline madmanmart
« Reply #9 on: 10 October 2012, 20:34 »
Yes they are.
