Author Topic: Oil Catch Can for the AGR Q's  (Read 4424 times)
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
« on: 09 October 2012, 11:23 »
Hiya all
Can someone point me in the right directing for putting a Oil Catch Can on my Mk4 Golf TDi [AGR] as i am pretty useless about it.
What pipes to replace, what piping to get how much pipeing, how big how to Etc Etc and if its even worth putting one on it.
Thanks in advance
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline godsANGER
Re: Oil Catch Can for the AGR Q's
« Reply #1 on: 09 October 2012, 21:23 »
liittle Bumpp
Offline Dalo Harkin
« Reply #2 on: 10 October 2012, 12:10 »
ebay is your best bet BUT the max inlet/outlet size is 15mm and the stock VW piping is 19mm I/D
so you will either need a company to make you some inlets that replace the 15mm standard ones and then you can use various tubing, I chose the one that was designed for oil but some dont, and you run a piece from the rocker cover to one of the inlets and then a piece from the puck that Ts into a piece to the oil breather under the inlet manifold and run the remaining piece back into the other inlet on the catch can.
Offline godsANGER
« Reply #3 on: 10 October 2012, 12:29 »
Thanks matei, so its going to be a pain regarding the pipe size then?
Offline rfn_hodgson
« Reply #4 on: 10 October 2012, 12:43 »
not really mate ive done the same as what dalo said and its not that hard of a job or even to source the materials. heres how ive done mine :
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline rfn_hodgson
« Reply #5 on: 10 October 2012, 12:43 »
now i just need to tidy it up :)
Offline Dalo Harkin
« Reply #6 on: 10 October 2012, 13:20 »
There was a guy on ebay that sold the piping as a catch can setup and unless you want to go for the expensive http://www.saikoumichi.com/ which already has 19mm inlet / outlet you need custom inlet / outlet making
Offline godsANGER
« Reply #7 on: 11 October 2012, 14:21 »
hoping to do this relatively cheap, how much would a inlets cost to have made up?
Offline Dalo Harkin
« Reply #8 on: 11 October 2012, 14:43 »
Cully had some for around £10, I got mine free from a friend, the issue with the ones I had made were one needed to be longer than the other because both pipes together were too wide to sit on the inlet/outlet side by side
Offline cullygti
« Reply #9 on: 11 October 2012, 18:55 »
i had 19mm stainless steel fittings custom made for £10 in a local engineering place and i also managed to get both pipes on side by side but as dalo said one would be better slightly longer to make it a bit easier when fitting the 2 pipes  :smiley:
