Author Topic: abs pump  (Read 1265 times)
Offline danmusic24
abs pump
« on: 08 October 2012, 20:34 »
Is it poss to bleed abs pump after changing it without having all four wheels off the ground and using vagcom?
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: abs pump
« Reply #1 on: 08 October 2012, 21:59 »
i would say so....although access will be tricky. I had my pump off and all stripped down, refitted and bled using the conventional two man method and no vagom. Abs light went out straightaway.
PS - Not sure if fitting another pump will need vagcomed though. It may well do.
« Last Edit: 08 October 2012, 22:01 by Gti_Jamo »
Offline danmusic24
Re: abs pump
« Reply #2 on: 08 October 2012, 22:06 »
That's what I would of thought,but after doing some reading up on it apparently the pump needs to run for a few seconds to purge itself? Well that's what the vagcom boys say.
Does seem a bit extreme.
Offline Gti_Jamo
Re: abs pump
« Reply #3 on: 08 October 2012, 22:12 »
I thought that too before doing mine......it did take me a while to get it right though.
Offline danmusic24
Re: abs pump
« Reply #4 on: 08 October 2012, 22:18 »
Nice one! Will give it a go then
