Author Topic: loud bang after full lock.  (Read 2054 times)
Offline mk3brick
« on: 08 October 2012, 11:36 »
hey guys,
i not so recently got rid of my coilies and fitted the standard shocks and h&r springs back to my golf as the coilies were driving me nuts :angry:, however since doing this i have noticed that when i go full lock on the steering wheel to park then return the wheel to centre there is a loud banging noise from whichever corner i have just full locked too (both sides do it). does anyone have any ideas? bearings shot in the top mounts maybe? they were new top mounts but not bearings when i changed my shocks back.
cheers
Offline DCmk3
Re: loud bang after full lock.
« Reply #1 on: 08 October 2012, 11:41 »
Perhaps it's the actual springs turning and creating the noise?
2014 Mk7 GTI - Littco L500
Offline mk3brick
« Reply #2 on: 08 October 2012, 12:34 »
i did grease up there perches pretty well though. its really weird but a fairly concerning bang  :undecided:
Offline WeekendMechanic
  • Golf MK3 GTD
« Reply #3 on: 08 October 2012, 13:11 »
Yea sounds like the springs are moving about, did you fit them correctly when you compressed the springs?
Offline mk3brick
« Reply #4 on: 08 October 2012, 14:03 »
yeah 100% do you have a suggestion to remedy this? cheers
Offline Leon27
« Reply #5 on: 08 October 2012, 20:09 »
Had a problem with my old Mk3 GL which did this but I agree with the others as it sounds too coincidental that it happened after changing back to shocks.
I changed top mounts and bearings, bottom ball joints and wishbones. Turned out to be the driveshaft! Strange one but was cured after replacing it.
Would check the springs are seating correctly, maybe get someone to turn the steering whilst you have a look to see whats going on if you haven't already?
Offline mk3brick
« Reply #6 on: 09 October 2012, 13:56 »
ok ill have another looksy to see what going on in there.
cheers for the help guys
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 09 October 2012, 18:47 »
Have you fitted the correct spring plates?
Offline mk3brick
« Reply #8 on: 10 October 2012, 09:45 »
yeah i had to fit the bigger of the two as the original springs had a smaller pigtail than the h&r's
