Author Topic: DRLs and Back Lights  (Read 1945 times)
Offline TurboTrev
« on: 06 October 2012, 21:19 »
My Golf R has DRLs and I was wondering if the back lights can be programmed to come when the ignition is switched on as per the DRLs?  I realise I could put the sidelights on which would put the back lights on, but on sidelights the DRLs dim down.  Ta.
Offline Buck
  • Das Auto
Re: DRLs and Back Lights
« Reply #1 on: 06 October 2012, 21:47 »
Trev
You can do this but need to programme it in using VCDS rather than it being an option in the MUlti Function Display/Settings
Offline TurboTrev
« Reply #2 on: 07 October 2012, 09:44 »
Trev
Thanks. :smiley:  Anyone know the coding for this?
« Last Edit: 07 October 2012, 09:48 by TurboTrev »
Offline Rhyso
« Reply #3 on: 11 October 2012, 13:32 »
Should be under Module 9 - Central Electronics - Coding
Use the long coding helper and it should be a tickable option - something like DRL's Scandinavian style or along those lines
 :nerd:
Offline Ginge 35Edition
« Reply #4 on: 11 October 2012, 13:47 »
Like the sound of this cos the rear LEDs look mint!
