Author Topic: Coming/leaving home  (Read 4793 times)
Offline KennyGTI
Coming/leaving home
« on: 06 October 2012, 20:01 »
Ok, I have the option set for coming and leaving home set via on board comp. now the car lights come on when I unlock the car in the dark ok but should they not come on once I open the car door at night? I had this set up on my gti but can't understand why it's not working on my R??
APR Stage 2+
Offline Buck
  • Das Auto
Re: Coming/leaving home
« Reply #1 on: 06 October 2012, 20:21 »
Kenny
IIRC you have to pull the left stalk (main beam flash) towards you before you get out to activate the coming home function
Offline RedHP
« Reply #2 on: 06 October 2012, 20:40 »
Kenny
Another IIRC (!), I agree that the coming home function is activated in the GiT once you have flashed your main beams
Red
Mk6 GiT since birth in 2010
YNWA
Offline dubber36
« Reply #3 on: 06 October 2012, 20:50 »
With the Mk6 you have to flash main beam once you have turned the ignition off, but it is possible to change the settings for the lights to remain on automatically, as they did in the Mk5 using VCDS. I've done mine, but it was a long time ago and I can't remember which box I ticked to do it.
Offline KennyGTI
« Reply #4 on: 06 October 2012, 21:42 »
So it's a vagcom job then. I must of done it aswell dubber but too long ago to remember!!
Want to set it up so it's automatic instead of flashing the head lights
APR Stage 2+
Offline Jimble
« Reply #5 on: 06 October 2012, 21:44 »
Is this part of the "rest of the world" setting?
Offline KennyGTI
« Reply #6 on: 06 October 2012, 22:07 »
Hmm I am on r.o.w setting just now for mph reading so not sure
APR Stage 2+
Offline Buck
  • Das Auto
« Reply #7 on: 06 October 2012, 23:00 »
Me too and I didn't have that optin re the lights so it must be something you set in central electronics?
Offline Ess_Three
« Reply #8 on: 07 October 2012, 09:34 »
It is...
I can't remember exactly where, but you can set leaving lights to come on when you unlock, and coming home lights to trigger either headlights or foglights (on a GTI etc) on either ignition off or door open.
I'm sure I have foglights coming on with door open on mine.
..but gaining motorcycles.
Offline sundaydriver
« Reply #9 on: 07 October 2012, 09:53 »
Changed mine also to activation on door opening, miles better than flashing before you get out.
http://www.golfgtiforum.co.uk/index.php?topic=219556.msg2027714#msg2027714
2012 Golf R, APR STAGE 2+, BCS power valve TB exhaust, loba HPFP, evoms intake, Rising blue, 19" Talladegas -BMW M2
