Author Topic: water in driver side rear?  (Read 1426 times)
Offline marksturbo
« on: 05 October 2012, 17:18 »
hi
ive recently noticed that after its been raining the rear footwell is soaking wet- this only happens on the driverside rear the rest of the car is fine
what could be causing water to be getting in the rear? boot is dry aswell.
thanks mark
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: water in driver side rear?
« Reply #1 on: 05 October 2012, 18:08 »
The seal that hold the window regulator to the door behind the door panel. Either the front or rear one as the water will always run to the back. Basically it involves removing the door panel and re-sealing either with a new seal from vw or some butyl strip off ebay. Don't use silicone thats for sure.
Have a wee search as its common and covered plenty times here.
PS - You can usually tell if its the seal if when you open the door and there is water lying on the door step. Should be leaking out between the door panel and door.
Offline barrym381
« Reply #2 on: 05 October 2012, 20:06 »
he is right an should know  :wink: (he owns a leon  :tongue: )
Offline Gti_Jamo
« Reply #3 on: 05 October 2012, 22:04 »
bah ha....i've only had to do one door..........twice!! :grin: :laugh:
Offline barrym381
« Reply #4 on: 05 October 2012, 22:18 »
:grin: :grin: i just done all 4 then got rid of car  :smiley: but its the seal round this panel for op
