Author Topic: 17563 manifold pressure sensor G71 ?????  (Read 7287 times)
Offline 1.6mk4GOLF16v
« on: 04 October 2012, 00:32 »
anyone know if this is refereing to my MAP sensor or am i totally off?
error code is:
17563 manifold pressure sensor G71 short to B+ P1155 - 35-10- intermittent
 :undecided:
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline barrym381
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Re: 17563 manifold pressure sensor G71 ?????
« Reply #3 on: 04 October 2012, 01:57 »
any ideas what this manifold presure thing looks like? googles bringing up loadsa diff pics  :undecided:
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
« Reply #4 on: 04 October 2012, 14:17 »
Can anyone confirm if a map sensor n a g71 is the same thing?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 04 October 2012, 18:43 »
G71 is the map sensor. bolted to the left hand side of the inlet manifold, more likely to be a wiring issue with that fault code though
« Reply #6 on: 04 October 2012, 18:55 »
Cheers gonna take a look at the wiring this weekend, kinda did suspect wiring as sometimes when i take a corner she gets her ass in gear n actually moves
Still getting use to the powerflex bushes aswell, did the front wishbones rear bush n dogmount aswell, stabilty is wicked, car shakes a bit though
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
« Reply #7 on: 06 October 2012, 19:02 »
After a eventful few hours tryin to get a broken clip of the map sensor, ive decided to buy some new wiring, only prob is i can find it online anywhere, im 99% sure its a wiring issue but i couldnt find any loose wires, also the wiring from the map sensor seem to join onto another set of wires, is it jus joined into a protective casing?, where can i but the MAP sensor wiring online?
« Last Edit: 06 October 2012, 22:40 by 1.6mk4GOLF16v »
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
« Reply #8 on: 08 October 2012, 22:18 »
anyone?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
« Reply #9 on: 12 October 2012, 15:56 »
HEEELP
really need to replace the map wiring but cant find it online newhere
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
