Author Topic: What to do with the broken MkII  (Read 1481 times)
Offline drumsofmassdestruction
« on: 03 October 2012, 20:18 »
Hello,
I'm new to all this.  I have recently been offered a 5 door big bumper MkII GTi to play with.  Apparently the cam belt snapped and it's buggered, I haven't had a look myself but I figured it might be a good opportunity to chuck something modern in i.e. a 20V turbo or alternatively a modern TDi engine.
I need advice on this though to know I won't be biting off way more than I can chew.
Suggestions gratefully received.
Offline Agreeable Slick
  • Unit
Re: What to do with the broken MkII
« Reply #1 on: 03 October 2012, 20:24 »
Have a read and use the search function through this section.
http://www.golfgtiforum.co.uk/index.php?board=7.0
Loads about mk2 conversions in there.
Offline Sam
  • Sam I am
« Reply #2 on: 04 October 2012, 09:23 »
Not really worth it on a 5 door...  :lipsrsealed:
Offline DubFan
« Reply #3 on: 05 October 2012, 03:55 »
How good is the shell?
If it's solid, no rust or dents, never crashed, then it might be worth the effort.
Nowt wrong with 5 doors.
If you're mechanically minded (which you didn't mention) then a conversion would be a good option. If you're a beginner, then a better bet would be to just replace the engine with another one exactly the same. A Mk2 GTI engine should be cheap enough to buy and at least then it should be straightforward to pull one out and put the new one in without having to worry about wiring, brakes, gearboxes and stuff.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #4 on: 05 October 2012, 12:42 »
STFU!
Offline Len
« Reply #5 on: 05 October 2012, 12:44 »
If its broke dont fix it! :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline Gambit
« Reply #6 on: 05 October 2012, 18:30 »
if its an 8v with a snapped cambelt then just stick a new belt on, its a non-interference engine so you cant do any damage with a snapped belt
