Author Topic: Dash clocks  (Read 2617 times)
Offline liss-liss
Dash clocks
« on: 03 October 2012, 19:06 »
Anyone know what number has to be matched up when replacing clocks?
there's that many different bloody ones  :undecided:
2.0 mk4 GTi
Just because I'm a girl doesn't mean I not a racer.
Offline richw911
Re: Dash clocks
« Reply #1 on: 03 October 2012, 19:56 »
You can use this table to make sure you get the right one:
IE: Vw part no 1J5 920 925A
1J0 = standard clocks / 1J5 - Bora sport
920 = can bus
9 = mph / 8 = km/h
2 = half mfa / 4 = fis
6 = imob III  5 = imob II
C = diesel  A=petrol
There are two versions on the MK4 paltform these being Immo 2 and Immo 3, earlier models came as Immobiliser 2 and in early 2001 VW introduced Immobiliser 3 with the vehicle immobiliser being integrated into the cluster.
You can tell which version you have by the part number of your cluster by the last numerical digit, 5 being immo 2 and 6 being immo 3.
EG: 1J0 920 926 C - immo 3 cluster / 1J0 920 925 C - immo 2 cluster
 You can put an immo 3 cluster into an immo 2 car (upgrade) but not an immo 2 cluster into an immo 3 car (downgrade)
* Anything but 6 on the end number is immo2 *
« Last Edit: 03 October 2012, 19:58 by richw911 »
Offline topher
  • Administrator
  • fully functioning
Re: Dash clocks
« Reply #2 on: 03 October 2012, 20:06 »
keep in mind that you'll need vcds or similar to adapt the new clocks to the car, and also a way of extracting the login code from them too. if you only have vagtacho its probably worth sticking to VDO manufactured clocks
Offline liss-liss
Re: Dash clocks
« Reply #3 on: 03 October 2012, 20:11 »
Thankyou that helped loads.!!  :smiley:
Im taking it to an autoelectrision so im assuming they will know what to do if i just poll up with these new clocks. :)
2.0 mk4 GTi
Offline markallen
  • AUM 1.8 20v Turbo 150bhp for now ;)
Re: Dash clocks
« Reply #4 on: 03 October 2012, 20:13 »
So if I was  put immo 3 into my 2000 AUM Mk4 I would need to get it recoded to work?
Golf Mk4 GTi Turbo, R32 front bumper, Lowered on ProSport Coilovers, Bora illuminated vents, Armrest, Heko wind deflectors, Aluminium vinyl trim.
Soon to be added, FMIC, 3" exhaust, Remap..oh and new turbo :(
Offline liss-liss
Re: Dash clocks
« Reply #5 on: 03 October 2012, 20:14 »
Yeah cos apparently there linked up to the ECU & IGNITION. so not just plug & play. if you dont get it coded the car wont start if im right?
2.0 mk4 GTi
Offline topher
  • Administrator
  • fully functioning
Re: Dash clocks
« Reply #6 on: 03 October 2012, 20:26 »
honestly i think an auto electrician would struggle with the job unless they're a vag specialist too. £50 to forum members at midland vw to fit and code the clocks, correct the mileage (vdo and motometer only) and reprogram all the keys :afro:
yep!
Offline liss-liss
Re: Dash clocks
« Reply #7 on: 03 October 2012, 20:32 »
Yeah there VW Audi specialist and there cheaper than £50 lol! Wish they didnt have to correct the millage cos its been to the moon and back lol! but really gotta get it done cos my mph is 20+ out!  :whistle:
2.0 mk4 GTi
