Author Topic: Power steering pump bearings  (Read 1241 times)
Offline Jimmyrallye
  • 20vt goodness
« on: 03 October 2012, 18:16 »
Evening chaps ,, my power steering pump decided to poop it self last night .. Can you just change bearings or is it new pump jobby ? Also would a mk3 pump fit  ? Thanks :)
Offline Jimmyrallye
  • 20vt goodness
Re: Power steering pump bearings
« Reply #1 on: 04 October 2012, 11:33 »
Its new pump time done some research you can use a mk3 pump but would also need alternator and brackets
Offline miggs2002
  • http://i42.photobucket.com/albums/e308/dubster16v/
« Reply #2 on: 05 October 2012, 12:40 »
if you know what you are doing then it is possible to change the bearings, you will need a new seal too, if the shaft has not contacted the inside walls of the pump then it's worth repairing it, i paid £120 for a recon pump with a 12 month warranty, 13 months later it died, my neighbour had a look at it for me and gave me the old bearing and seal to replace, i got the new parts for £6 and it lasted another 4 years after that, may still be going but sold the engine s i don't know
and no a mk3 pump pulley wheels sits out a touch further than the mk2 so the belt will be at an angle
