Author Topic: Coolant leak (part numbers needed)  (Read 2380 times)
Offline ian007miles
« on: 02 October 2012, 09:13 »
Hi I have a coolant leak on the right hand side of the engine so I'm going to investigate at the weekend wot I wanted to no is does any one no where I can get the metal water pipe from?does Vw still do it and what the part number is? And the plastic water pipe that bolts to the head where all the water pipes go to what the part number for that is as well and the rubber O Ring that goes behind that thanx Ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline miggs2002
  • http://i42.photobucket.com/albums/e308/dubster16v/
Re: Coolant leak (part numbers needed)
« Reply #1 on: 02 October 2012, 09:21 »
model of car i assume is mk4, engine is??
if you can let me know what engine you have i shall have a look on ETKA for you
Offline ian007miles
« Reply #2 on: 02 October 2012, 09:24 »
Lol sorry mate 1999 18T 150 agu Gti mk4 golf T reg thanx
« Last Edit: 02 October 2012, 09:29 by ian007miles »
Offline miggs2002
« Reply #3 on: 02 October 2012, 16:14 »
is it the one numbered 10? the blue circle?
appologies for asking but i have never worked on a 1.8t engine
Offline ian007miles
« Reply #4 on: 02 October 2012, 18:10 »
Na I think the metal pipe is number 34
Offline ian007miles
« Reply #5 on: 02 October 2012, 18:24 »
Sorry mate yeh it's number 10 and the other bit I need is the plastic pipe that bolts to the head with the temperature sender in it
Offline miggs2002
« Reply #6 on: 03 October 2012, 07:57 »
is it this one?
there are 2 part numbers available for the AGU engine depending on chassis number, the bit where it says description is chassis numbers up to in the top box and from in the one under it
Offline ian007miles
« Reply #7 on: 03 October 2012, 11:14 »
Yeh mate that's like it. Do u no if theses parts are still available thanx Ian
Offline miggs2002
« Reply #8 on: 03 October 2012, 14:16 »
it's showing up with part numbers on ETKA so they should be, most mk4 stuff is readily available still
call TPS and give them the part number, they will be cheaper than VW
Offline ian007miles
« Reply #9 on: 03 October 2012, 14:25 »
The last time I rang tps they said a couldn't order from them coz I wasn't a business
