Author Topic: Mk3 Fog Lights  (Read 1683 times)
Offline ss2115
Mk3 Fog Lights
« on: 02 October 2012, 05:43 »
I've installed clear lense tailights and front indicators to my daughters Golf to smarten it up a bit.
The front replacement lights came with Fog Lights.
The car has a fog light switch (pull out the headlight switch). All it seems to do is light up the front parker globes, and a seperate small gobe in the tailight cluster behind each red section.
I've had a quick look around the headlights looking for any unused plugs for the fog light option as most German cars always install a full loom whether the options are being used or not. But I couldn't see anything obvious.
Has anyone done this before? Are the plugs there but I just haven't found them?
If they aren't there, I'll probably just wire the fogs into the high beam headlight circuit, but I'd like them to switch on individually as they are supposed to if possible.
1997 Golf mkIII
1993 BMW 525i touring
1974 Citroen DS23 Safari BVH
Offline benjy_b
Re: Mk3 Fog Lights
« Reply #1 on: 02 October 2012, 08:00 »
You will require a new headlight switch with 2 stages when you pull it out, first stage is front fogs and second stage is rear fog (it also has both symbols on). Also, you will require a front headlamp loom, including fog connections. I paid £30 delivered on eBay for both.
1995 MK3 Volkswagen Golf 1.9 TDI CL 3 Door - White
Offline Len
Re: Mk3 Fog Lights
« Reply #2 on: 02 October 2012, 12:47 »
Wiring loom is probably not there either!
And I think on mine its rear fogs first then front and rear fogs on two stage switch as I cant have front fogs only on.
BTW - Like to see pics of your Citroen Safari!
www.sas.org.uk
www.the-ace.org.uk
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Mk3 Fog Lights
« Reply #3 on: 02 October 2012, 12:53 »
If it didnt come fitted with foglights then front piece of loom wont be there
Im selling one as it happens...  :wink:
Offline Len
Re: Mk3 Fog Lights
« Reply #4 on: 02 October 2012, 12:57 »
Dont think he would want to pay the carriage to AUSTRALIA! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Re: Mk3 Fog Lights
« Reply #5 on: 02 October 2012, 13:10 »
It'd be rude not to try though.  :tongue:
