Author Topic: lower arms .. all the same ?  (Read 1077 times)
Offline spudboy6
  • Just like a golf ......
« on: 01 October 2012, 23:19 »
need new lower arms for my 1995 1.8 mk3 , are all lower arms the same on the mk3 or are there some changes ?
thanks .
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: lower arms .. all the same ?
« Reply #1 on: 02 October 2012, 00:02 »
They are different depending on model. Drop link mounting point.
Offline berry9112
« Reply #2 on: 02 October 2012, 08:39 »
They are different, gti/vr6 has wider tracking and as mentioned different arb mounting points. From VW they are £106+VAT a side. Then you need the balljoint ect. I got balljoint bushes and arms both sides from a place called B and B components in maidstone for £93 after recommendations on here.
Just a heads up aswell, i went to do mine on friday and the front bolt snapped in the subframe and i havnt been able to get it out! Im now looking for a new subframe. If you can, wd40, a blow torch and a impact air gun. Mine was really stuck though!
Hope this helps bud.
