Author Topic: Mk3 2.0 8v pinking, why??  (Read 2864 times)
Offline Turbotezz
  • New Dubber
« on: 01 October 2012, 20:56 »
Hello chaps!
Right, since i have had my golf, I have had pinking when under any load from the engine.
I first checked the plugs, they are fine, replaced the Dizzzy cap. Bought a cheap vag-com and found the dizzy was out a little, corrected that. Changed the fuel filter and gave it a can BG 44K and still the same amount of pinking!!!
I ran fault codes on the engine and nothing came back.
Whats next to try?? There still seems to be plenty of pull to the engine, still hits the limiter.
Any ideas will be greatly appreciated!
Offline Luke1981
Re: Mk3 2.0 8v pinking, why??
« Reply #1 on: 01 October 2012, 21:01 »
Cracked or damaged exhaust manifold maybe?
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 01 October 2012, 21:04 »
Maybe previous owner chipped the ecu which has aggresive advanced ignition timing ,try some 98ron petrol see if that stops it.
Offline Turbotezz
  • New Dubber
« Reply #3 on: 01 October 2012, 21:09 »
I thought initially that it may have been exhaust but i really dont think it is.
When this tank full is done i will try some tesco 99 RON, but i dont really want to have to be getting super all the time, it will cost a bloody fortune as this is my only car thus my daily!
It  has been suggested that it could be the knock sensor even though its not throwing up a fault code
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 01 October 2012, 21:29 »
Knock sensor could be a good call actually .probably wont throw a code in all cases .id still try a tenner of 99 though  :smiley:
Offline tweed
« Reply #5 on: 01 October 2012, 21:45 »
My BMW used to do it. It's a common problem for them and its a cam position sensor. But that was only around 3000
You sure it's pinking and not miss firing?
I would change the plugs.
Offline Turbotezz
  • New Dubber
« Reply #6 on: 02 October 2012, 06:42 »
defo pinking. the plugs are fine. will look for a knock sensor. is there anyway of testing to see if it's gone before I change it?
Offline tweed
« Reply #7 on: 02 October 2012, 07:37 »
I wouldn't know mate
Offline Turbotezz
  • New Dubber
« Reply #8 on: 02 October 2012, 20:45 »
gave the keys to some experienced ears today. Guess what, its the bloody exhaust, like i thought it was when i had the car! Grrrr, soooo miffed i listened to so many other people when all along it was what i though!
Offline tweed
« Reply #9 on: 02 October 2012, 21:39 »
You sure  :grin:
