Author Topic: MK2 Electric mirrors fitting How to  (Read 38453 times)
Offline H Singh
« on: 01 October 2012, 09:40 »
Guys ihave finally got hold ofa complete set up the loom and switches etc.
So now i need some help on how to fit it? does anyone know or has anyone fitted any?
Where is the live, ground pluged into and how can i do it so that it only works when the ignition is turned on? or has people fitted it so it works even when the car is off, surely the battery will die this way too?
« Last Edit: 03 October 2012, 18:16 by Agreeable Slick »
Offline dubber36
Re: MK2 Electric mirrors fitting? How to?
« Reply #1 on: 01 October 2012, 17:12 »
I'm guessing at this, but is your loom similar to the electric window one? That has a relay, switches, wires to the motors and three wires to connect to the fusebox. A live, and earth and and ignition live that energises the relay.
Offline Mr Blue
« Reply #2 on: 01 October 2012, 20:30 »
Sengh IIRC you have an earth (brown), a live (yellow black) and a heater (white/green)
You need to drill out the rivets for the manual adjuster brackets and bin them.
3 phillips head screws behind the door cover for the mirror. Fit leccy mirrors in, feed the wiring through and thats the hardest bit done.
Find any ignition live at the back of the fuse box. I think I tapped into a spare plug laying around but if you don't have a multi meter I wouldn't chance it.
Earth goes on the earth plate near pedals,
Location: P/02 Rear Window Defogger Switch, - Yellow Black wire
Location: P/03 Rear Window Defogger Switch - White/ green wire
http://www.a2resource.com/electrical/CE2.html
« Last Edit: 01 October 2012, 23:00 by Mr Blue »
Offline H Singh
« Reply #3 on: 02 October 2012, 10:16 »
Thanks for the help guys, ima attempt to fit this in using this so ill let you know how i get on :)
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 02 October 2012, 16:41 »
Here is a link to when I fitted mine...
Mirror Wiring;
« Last Edit: 02 October 2012, 16:43 by X4MGS »
For More Info Click To See;
Offline H Singh
« Reply #5 on: 03 October 2012, 16:09 »
Cheers guys thanks for the help all fitted in and working correctly! :)
