Author Topic: DPF light on - Update: Now Sorted - I hope!  (Read 22203 times)
Offline Buck
  • Das Auto
Re: DPF light on - Update: Now Sorted - I hope!
« Reply #40 on: 16 January 2013, 23:58 »
It does - thanks Dunc
Offline Keithuk
« Reply #41 on: 24 January 2013, 21:35 »
There are 34 error codes for the Diesel Particulate Filter (DPF).
EOBD II Error Code: P260E - Diesel Particulate Filter (DPF) Warning Lamp - Control Circuit Malfunction
EOBD II Error Code: P24A2 - Diesel Particulate Filter (DPF) Regeneration - Regeneration not completed
EOBD II Error Code: P24A1 - Closed Loop Diesel Particulate Filter (DPF) Regeneration Control, Control Limit Reached - Temperature too High
EOBD II Error Code: P24A0 - Closed Loop Diesel Particulate Filter (DPF) Regeneration Control, Control Limit Reached - Temperature too Low
EOBD II Error Code: P249F - Excessive Time To Enter Closed Loop Diesel Particulate Filter (DPF) Regeneration Control
EOBD II Error Code: P246D - Diesel Particulate Filter (DPF) Pressure Sensor - A/B Correlation
EOBD II Error Code: P246C - Diesel Particulate Filter (DPF) - DPF Restricted, Limp-Home Mode Activated
EOBD II Error Code: P246B - Diesel Particulate Filter (DPF) - Vehicle Conditions Incorrect
EOBD II Error Code: P2465 - Diesel Particulate Filter (DPF), Bank 2 - Differential Pressure too High
EOBD II Error Code: P2464 - Diesel Particulate Filter (DPF), Bank 2 - Differential Pressure too Low
EOBD II Error Code: P2463 - Diesel Particulate Filter (DPF) - Excessive Soot Accumulation
EOBD II Error Code: P2462 - Diesel Particulate Filter (DPF) Pressure Sensor B - Circuit Malfunction
EOBD II Error Code: P2461 - Diesel Particulate Filter (DPF) Pressure Sensor B - Circuit High
EOBD II Error Code: P2460 - Diesel Particulate Filter (DPF) Pressure Sensor B - Circuit Low
EOBD II Error Code: P245F - Diesel Particulate Filter (DPF) Pressure differential Sensor B - Circuit Range/Performance
EOBD II Error Code: P245E - Diesel Particulate Filter (DPF) Pressure Sensor B - Circuit Malfunction
EOBD II Error Code: P2458 - Diesel Particulate Filter (DPF), Regeneration Process - Duration Malfunction
EOBD II Error Code: P2456 - Diesel Particulate Filter (DPF) Pressure Sensor A - Circuit Malfunction
EOBD II Error Code: P2455 - Diesel Particulate Filter (DPF) Pressure Sensor A - Circuit High
EOBD II Error Code: P2454 - Diesel Particulate Filter (DPF) Pressure Sensor A - Circuit Low
EOBD II Error Code: P244F - Diesel Particulate Filter (DPF), Bank 2 - Exhaust Temperature too High for Regeneration
EOBD II Error Code: P244E - Diesel Particulate Filter (DPF), Bank 2 - Exhaust Temperature too Low for Regeneration
EOBD II Error Code: P244D - Diesel Particulate Filter (DPF), Bank 1 - Exhaust Temperature too High for Regeneration
EOBD II Error Code: P244C - Diesel Particulate Filter (DPF), Bank 1 - Exhaust Temperature too Low for Regeneration
EOBD II Error Code: P244B - Diesel Particulate Filter (DPF) - Differential Pressure too High
EOBD II Error Code: P244A - Diesel Particulate Filter (DPF) - Differential Pressure too Low
EOBD II Error Code: P242F - Diesel Particulate Filter (DPF), Bank 1 - Restricted/Clogged
EOBD II Error Code: P200D - Diesel Particulate Filter (DPF), Bank 2 - Over-Temperature Condition
EOBD II Error Code: P200C - Diesel Particulate Filter (DPF), Bank 1 - Over-Temperature Condition
EOBD II Error Code: P2459 - Diesel Particulate Filter (DPF) - Regeneration frequency
EOBD II Error Code: P2002 - Diesel Particulate Filter (DPF) Bank 1 - Malfunction
EOBD II Error Code: P2452 - Diesel Particulate Filter (DPF) Pressure Sensor A - Circuit Malfunction
EOBD II Error Code: P2453 - Diesel Particulate Filter (DPF) Pressure Sensor A - Implausible Signal
EOBD II Error Code: P3071 - Reservoir for Additive for Diesel Particulate Filter (DPF) - Empty
EOBD II Fault Codes Software
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline Rhyso
« Reply #42 on: 24 January 2013, 22:04 »
Awsum  :grin: :grin: :grin:
I can safely say my Aldi NEVER saw any of those  :smug:
Offline Buck
  • Das Auto
« Reply #43 on: 25 January 2013, 09:13 »
Unfortunately wasn't any of those - and that initself was the problem - anyways pressure sensor now replaced and it seems to be running fine now - needs a bl00dy good clean but that's for another day ;)
Offline Buck
  • Das Auto
« Reply #44 on: 25 January 2013, 09:14 »
Yep - miss my Aldi - although it did die on me in the end was a great car  :cry:
Offline TJD
  • The quality remains after the cost is forgotten.
« Reply #45 on: 12 March 2013, 12:41 »
Hi -
I'm just about to replace my G450 sensor for roughly all the same reasons explained above (I won't go into boring detail).
Can anyone tell me how do I actually ADAPT it to the car??
I have VAGCOM
Thanks
MK6 GT140. Reflex silver. Vancouvers.
Offline Buck
  • Das Auto
« Reply #46 on: 12 March 2013, 23:35 »
Sorry I don't know but Rhyso may well be your man.
« Last Edit: 12 March 2013, 23:42 by Buck »
Offline topher
  • Administrator
  • fully functioning
« Reply #47 on: 14 March 2013, 20:39 »
go to engine, click login (might be coding can't really remember) hover your cursor over the input field and you should get a list of codes for dpf regeneration and G450 adaptation.. its 30605 from memory then ignition off for 30 secs, but I tend to use autologic for things like this instead. Its just one button press :grin:
Offline TJD
« Reply #48 on: 26 March 2013, 21:41 »
Thanks Topher.
