Author Topic: Engine oil  (Read 12558 times)
Offline Snooze
Engine oil
« on: 30 September 2012, 12:38 »
Hi guys is 5w30 the correct oil grade for my mk6 golf gti? Thanks
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline Buster73
Re: Engine oil
« Reply #1 on: 30 September 2012, 15:05 »
Lost your manual ?
Offline mkviken
Re: Engine oil
« Reply #2 on: 30 September 2012, 16:59 »
Does it not say on be filler cap? Sure it says use castrol and the weight required.
Golf GTI 7.5 230 white silver
Offline Ginge 35Edition
Re: Engine oil
« Reply #3 on: 30 September 2012, 18:39 »
Offline Snoopy
  • Moderator
  • Geoff.
Re: Engine oil
« Reply #4 on: 30 September 2012, 19:15 »
http://www.golfgtiforum.co.uk/index.php?topic=65779.0
Well worth a read, only use Approved oils not meets oils  :wink:
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Snooze
Re: Engine oil
« Reply #5 on: 05 November 2012, 14:03 »
Still a little lost on what oil I should be using in my car.  And after receiving various different answers from different sources I am now even more confused!   :undecided:
My cars on the annual service regime and my manual says I should use the 502.00 spec oils.  Now this spec in itself is not very clear because it lists out several different oil grades:  0w-30, 5w-40, 10w-40, 5w-50, 0w-40 & 5w-30.  Now which of these oils should I be using, and is any particular one better than another?
The Stealer I bought my car from says I should be using 10w-40.
Most websites/forums tend to suggest 5w-30 is the way to go.
Halfords says I should be using 5w-30.
Can anyone what oil I should be using and out of the various options which is the best oil to use?  Many thanks
« Last Edit: 05 November 2012, 15:58 by Snooze »
Offline Edi35
Re: Engine oil
« Reply #6 on: 05 November 2012, 15:41 »
My cars on the annual service regime and my manual says I should use the 504.00 spec oils.  Now this spec in itself is not very clear because it lists out several different oil grades:  0w-30, 5w-40, 10w-40, 5w-50, 0w-40 & 5w-30.  Now which of these oils should I be using, and is any particular one better than another?
Yes 504 spec is correct and ensure that you use the normal not long life stuff and change it every 12 months or 10,000 which ever comes first. My ED30, MK6 and ED35 never used/use enough oil to warrant me buying any between services.
Current: GTI Edition 35 Candy White 5dr DSG 19" Glendale, RCD510+DAB, Dynaudio, Storage Pack, Parking Sensors
Gone: Edition 35, GTI Mk6, Edition 30, GTI Mk4, GTI Mk3, GTI Mk2 and my favourite the UR quattro
For those that dont know DSG is an electronically controlled dual-clutch multiple-shaft manual gearbox
MonkeyP
Re: Engine oil
« Reply #7 on: 05 November 2012, 16:45 »
i used Castrol Edge 5w-30 for my car as thats the recommended one.
I know in the service they us Shell helix tho!  :undecided:
Offline Snoopy
  • Moderator
  • Geoff.
Re: Engine oil
« Reply #8 on: 05 November 2012, 19:07 »
Mine was billed to VW as using
Platinum 5 40
At its last two services at the main dealer
Quote
from the link i posted earlier
non-LongLife Time and Distance servicing for petrol engines is 502.00.  This is usually a fairly high spec 'fully synthetic' oil, SAE 5W40
Longlife oil
504.00 - is the spec for petrol engines, this is the latest VW LongLife "3" specification.  SAE 5W30.
Note about my photo of my oils
The Castrol edge is the longlife oil 5W30
The VW Quantum platinum is the non longlife oil 5W40
« Last Edit: 05 November 2012, 20:42 by Snoopy »
Mk6 GTI  &  Mk1 GTI
Offline Snooze
Re: Engine oil
« Reply #9 on: 05 November 2012, 22:12 »
Brilliant 5w-40 it is then! Thanks Snoopy. I suppose I should have known really as that's what I use to put in my Mk5 gti! I just thought perhaps it might be different with the mk6. Cheers
