Author Topic: Hi all, bought a 16v and now  (Read 2991 times)
Offline YODI
« on: 11 July 2005, 08:44 »
Hi guys and gals,
bought a j plate 16v gold from the pod yesterday, well infact it was the one parked up just before you get to the pod. Lovely car and im really happy with it BUT I want a bit more power.
Who sells the panel filters?? Other than that and an exhaust is there anything else I can do for a bit more power??
Thanks, Yodi
Offline Gambit
Re: Hi all, bought a 16v and now
« Reply #1 on: 11 July 2005, 11:12 »
aye you can get the Warm Up Regulator adjusted to up the control pressure and make the car more responsive
do an advanced search on "WUR" and "Warm Up Regulator" in garage and mk2. i detailed what its about a while back
Judderi
« Reply #2 on: 11 July 2005, 11:38 »
Could also swap the bottom end for a 2 litre from a passat.
Offline Organisys
  • Old and Slow...
« Reply #3 on: 11 July 2005, 12:24 »
AS for the filter and exhaust you mentioned, good options are a k&N panel filter and a Miltek full exhaust with downpipe if you can afford it.
Judderi
« Reply #4 on: 11 July 2005, 12:31 »
Could also splash out on a 4 branch stainless exhaust manifold. Theres also the option of changing your intake manifolds for the larger size if you currently have the smaller ones. This should increase your top end.
Offline YODI
« Reply #5 on: 11 July 2005, 12:35 »
hi guys, thanks for your help
I dont want majot power and wont be changing engines etc..
Any idea on prices??
Its also got one of them ecotek valves, shall I bin it??
Offline YODI
« Reply #6 on: 11 July 2005, 19:01 »
also are the air filter on a j plate car the same as pre 90???
Yodi
Offline YODI
« Reply #7 on: 12 July 2005, 12:23 »
 :cry: :cry: :cry: :cry: :cry:
Offline Organisys
  • Old and Slow...
« Reply #8 on: 12 July 2005, 12:58 »
Have a look here mate, www.awesomegti.com There prices are a little high, but you get the idea....
The filters do come up on ebay.
Offline YODI
« Reply #9 on: 12 July 2005, 23:38 »
thanks mate, ive seen a few on ebay and they are £55 from halfrauds but i just wanted to know is the filter off any other golf the same as the j plate 16V??
