Author Topic: Inner Driver CV Boot  (Read 2787 times)
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
« on: 30 September 2012, 11:12 »
Anyone got a guide or info on how to change the inner CV boot on the drivers side? Tools that i need and any difficulties i may run in to?
Cheers!  :wink:
Mk4 Gti - Gone but not forgotten!
Offline JimBR
Re: Inner Driver CV Boot
« Reply #1 on: 30 September 2012, 12:03 »
Gloves!
Horrible messy job.
Offline Xtrhardcore
« Reply #2 on: 30 September 2012, 12:10 »
Haha I can imagen! not good times!
Offline Steve_PD
« Reply #3 on: 30 September 2012, 12:20 »
Need to remove the driveshaft.
So you need to undo the hub nut think it a 30mm 12 point socket.
Rubber mallet to knock the driveshaft out the hub.
Undo the 3 balljoint bolts on the hub M8 bolts 13mm socket so that you can swing the hub out the way.
Then either M8 or M10 spline socket to remove the 6 bolts on the gearbox.
Think its just a circlip then to remove the cv joint to get the old boot off.
Gloves are a must as the grease gets everywhere!
Make sure the new boot is rubber and dont buy from GSF :lipsrsealed: They dont last long.
Ill see if I can find a guide
Offline Steve_PD
« Reply #4 on: 30 September 2012, 12:26 »
Offline Xtrhardcore
« Reply #5 on: 30 September 2012, 12:41 »
Perfect thank you :)
