Author Topic: abf firing order won't start  (Read 4781 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« on: 29 September 2012, 12:45 »
can some one please confirm the order. car will not fire up after engine clean up.
I think its        34
                     12
« Last Edit: 29 September 2012, 15:07 by oakgreengolf »
Offline Screech16v
  • MK3 20vt AGU
Re: abf firing order
« Reply #1 on: 29 September 2012, 12:55 »
1 3 4 2   :wink:
Re: abf firing order not starting
« Reply #2 on: 29 September 2012, 15:06 »
so looking at the car from the front  number 1 would be front left. 3 back left . 4 back right 2 front right. I have it in this sequence and it will not fire. I had taken apart the dizzy to replace the seal and am pretty sure I reasembled it correctly. there is definatly fuel getting through and all the leads are producing a spark. I had forgot to plug the hall sender in when I first started it up and it did make a loud pop backfire type noise. any suggestions greatly apreciated.
Offline tweed
Re: abf firing order won't start
« Reply #3 on: 29 September 2012, 17:31 »
Is the timing marks all lined up when cylinder 1 is tdc?
« Reply #4 on: 29 September 2012, 18:43 »
With cylinder 1 at tdc the rotor arm is pointing at number 1.
Offline sam1990
« Reply #5 on: 29 September 2012, 20:00 »
swap 3 and 4 around
Offline tweed
« Reply #6 on: 29 September 2012, 20:41 »
Is it putting to the mark on the housing?
My number one is back right.
« Reply #7 on: 30 September 2012, 09:09 »
Back right number 1??. That would mean my dizzy is possibly 180 deg out. I'm really confused now  :sad:
Offline tshirt2k
  • Been there...Done that...
« Reply #9 on: 30 September 2012, 12:38 »
ABF has a locked dizzy. Think it can only go on one way.
Mk3 ABF 16VT Megasquirt V3
