Author Topic: 16v gti top end rattle when warm.  (Read 2160 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« on: 28 September 2012, 21:48 »
Hi all
I have a mk2 16v kr which has developed a top end rattle when warm. From cold its fine,I took it to the workshop and they stripped the top and looked at the cams etc. They advised a new cam chain as I has some play in it.They said the camshafts are perfect.
I have just got the new chain but before i take it in to be done I was wondering if maybe I should get a new set of followers or something else as I only want to pay for this to be done once.
Offline Mr Blue
Re: 16v gti top end rattle when warm.
« Reply #1 on: 28 September 2012, 23:10 »
edit: was thinking about the 1.8t then.
Don't forget the new gaskets etc.
« Last Edit: 28 September 2012, 23:29 by Mr Blue »
Offline 01664gti
« Reply #2 on: 29 September 2012, 10:42 »
Ok cheers i have them already,I did forget to mention that i also get a rattle on start up for about 1 second.
Offline danny_p
« Reply #3 on: 29 September 2012, 11:13 »
beware of new followers.
a mates one was doing tis and we'd done the chain   and put new followers in it   after a bit it started ratteling and reporting low oil pressre and really ratteling when hot que new oil pump and shells,  was ok fo a bit then started doing it again,   ended up being the new tappets they were trying to fall apart removein g tem from the head all the centers fell out
all the VW's have gone bar 1.
