Author Topic: Hi i need some urgent advice please  (Read 6904 times)
Offline sexysam777
« on: 27 September 2012, 21:33 »
Hi i have a golf mk5 1.9tdi the problem i have is that when the car is cold it starts perfect without any problem, but when the car is warm it hesitates and takes about 5 seconds to start but when it starts the car runs fine. It hesitates to start when the temperature is on 90
Iv installed new glow plugs but still has the same problem, and just today iv installed a new coolant temperature sensor but still the same problem
I researched and some forums are saying it might be the air mass sensor,
Has anyone have any ideas what could be causing this thank you
Offline forewheels
  • in repair mode
Re: Hi i need some urgent advice please
« Reply #1 on: 29 November 2012, 01:26 »
mine does this, i think its just the drain from the battery. it normally starts fine when cold but just takes a few seconds as the charge drops a little bit after use, as long as the car starts each time i wouldnt think there is a problem really.
