Author Topic: SPARK PLUGS DIRTYING UP......HELP!!!  (Read 992 times)
Offline Matthew Green
« on: 27 September 2012, 20:07 »
hi all,
my 2.o 8v v reg 107k is having a problem running properly. The spark plugs are becoming dirty, the car is running rough in idle and its having a loss of power at below 2000rpm. My local garage dont have a clue and when I asked about similar issues on here a few months back, I was advised to clean the tb, which I did with a friend who knows what he is doing. On cleaning tb we noticed some oil which we think came from the breather tube? but cleaning it didn't realy help. only 1 spark plug is sooting up, but it is also wet with oily residue.
thinking maybe the breather oil, or maybe piston rings?? any thoughts?
thanks
Offline mar_k
Re: SPARK PLUGS DIRTYING UP......HELP!!!
« Reply #1 on: 28 September 2012, 19:44 »
I'd start by getting the car scanned to see if any faults come up,
Then get a comp test done,
Do it dry and then wet to see if there is an improvement.
The 2.0 is known for worn piston rings and the above test will give an indicator.
Offline james2
  • No scammers please.
« Reply #2 on: 28 September 2012, 20:50 »
The oil must be getting past the valve stem oil seal.  :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline vii-cks
« Reply #3 on: 29 September 2012, 08:44 »
I had an issue with my mk4 but was 1.4 with one spark plug getting oily but it was the rocker cover gasket, in your case with the rough running sounds like something internal. You can buy yourself a compression tester and get that done yourself.
Offline james2
« Reply #4 on: 29 September 2012, 17:17 »
compression test will not show the valve stem oil seal leaking.I had this happen on my old ford fiesta.
Offline AD1.8T
« Reply #5 on: 29 September 2012, 19:58 »
If it was my id replace rocker cover gasket and buy new plugs ! Is it oil getting on them ?
