Author Topic: Where does the ignition coil get power from?  (Read 1031 times)
Offline GOLF-MK3-GTI
« on: 26 September 2012, 21:21 »
As above, would like to know what powers the ignition coil, I know it's the coil amplifier, but what sends the power into the amplifier, for it to go through the coil?,
is it the ignition switch?
My mk3 don't give out spark, I've tried a few ignition coils, but still no spark,
so I'm thinking if it's ignition switch?
Thanks
Offline sam1990
Re: Where does the ignition coil get power from?
« Reply #1 on: 26 September 2012, 22:10 »
its more likely to be the distributor or leads
Offline javalin
« Reply #2 on: 29 September 2012, 19:37 »
could also be crank or cam sensors (depends on model) - if the ECU doesn't see engine rotation it won't spark....  If you directly connect the king lead to a plug, does that spark?
Voltmeter?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
