Author Topic: Audi A5 Enhancement Detail  (Read 3118 times)
Offline butler2.8i
« on: 26 September 2012, 20:25 »
Products and equipment used
Uber microfiber towels
Chemical guy’s woolly mammoth drying towel
3m yellow pads 150mm 75 mm
140 mm Glazing pads
Halogen site lights
Makita rotary polisher
DA Polisher
Chemical Guys Glossworkz Glaze
Chemical Guys Celeste dettaglio v2
Carpro Fixer polish
Carpro eraser
Carpro Ironx
3m masking tape
Meguiars APC
Costco microfibre towels
Meguiars hyper dressing
Valet pro citrus bling
Valet Pro Bilberry wheel cleaner
Valet Pro PH neutral Snowfoam
Valet pro tyre dressing
AMDetails AMbubbles
Bilt Hamber clay bar
Autosmart Tardis
Various brushes
Kranzle pressure washer
Carpro Sheepskin wash mitt
Carpro Dlux
Noodle wash mitt
Carpro Lambs wool wash mitt
Poorboys microfibre clothes
Uber buffing clothes
Autobrite Snow foam gun
Chemical guys Jetseal 109
Autobrite Repel
Auto Finesse Mecury Metal Polish
00 grade wire wool
The wheels were cleaned using valet pro bilberry wheel cleaner befor ebeing given a hit of Carpro ironx the was then given its first coat of snow foam whilst this was dwelling I went round the car using APC in a foaming head bottle cleaning the fuel filler area and various gaps and grills. The snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and the car was washed using the 2 bucket method with grit guards in both buckets and a Carpro lambswool wash mitt.
The car was then rinsed off using an open ended hose and I then went round the car with Tardis which was left to go to work before being wiped down with microfibre clothes. The car was then given a coat of Ironx again left to do its stuff before the car was washed down using the pressure washer.
The car was clayed using citrus bling and water mix (10 to 1) and a Bilt hamber soft clay bar which helped to pull more contaminates from the paint work it was then rewashed using the same method and dried using the woolly mammoth.
Outside cleaning shots
I then taped the car up and went round with various yellow 3m pads and Carpro Fixer polish, each panel was given a wipe down with Carpro eraser after polishing to check finish and remove any polishing oils.
I then went round the car and applied a coat of Chemical guys Glossworkz Glaze using the DA and the lake county pad which was left before being buffed using Uber buffing towels.
The car was given 2 coats of the Chemical Guys Celeste dettaglio v2 wax leaving wax to bond for 60min and approx 60min between each coat again buffed using Uber buffing towels
The plastic trim was dressed using Carpro Dlux which is a cracking product which a little goes a long way and gives a stunning finish.
After this I cleaned the glass and gave them all 2 coats of Autobrite repel
The alloys were sealed using 2 coats of Chemical guys and dressed the tyres using the Valet pro tyre dressing.
Finished shots
Here’s a link to my facebook page
http://www.facebook.com/NorthEastCarCareUK
Offline Mr GTD
Re: Audi A5 Enhancement Detail
« Reply #1 on: 26 September 2012, 21:25 »
Another masterpiece Butler, keep them coming, love reading these.... :cool:
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #2 on: 27 September 2012, 14:32 »
Lovely job. Love the wheels on that Audi  :cool:
I'v got a feeling you are copying and pasting the first part where you mention all of the products used...Just a hunch  :wink: :tongue:
Offline butler2.8i
« Reply #3 on: 28 September 2012, 19:28 »
Tis true as i have them saved as a template and just change the ones i need for each car  :embarrassed:
Offline Mr GTD
« Reply #4 on: 28 September 2012, 23:45 »
Don't blame ya tbh, as you use roughly the same products with a few tweaks here and there it makes sense...constantly having to write the same wud do my nut in...
Offline vii-cks
« Reply #5 on: 29 September 2012, 08:42 »
Much better! Alot of Audi's I feel still have that little orange like peel looking panels which come up great when people have gone and done a proper polish!
