Author Topic: No Heat..plz help!!  (Read 2381 times)
Offline SHAKSTER
No Heat..plz help!!
« on: 06 October 2003, 14:43 »
Its getting colder but i dont get any warm air . Ive changed the heater matrix but still no luck.
When i just start the engine, i get heat for the first say 5-8 mins but then it gets cold.
help!! plz!!
golfvr6
Re:No Heat..plz help!!
« Reply #1 on: 06 October 2003, 14:54 »
Does the car run ok? or does it overheat? Sounds like a blockage in one of the pipes going into the matrix maybe. Thats presuming there is coolant in the system  ;)
Offline SHAKSTER
« Reply #2 on: 06 October 2003, 15:03 »
The car runs fine and their is coolant... :P
any more ideas?
golfvr6
« Reply #3 on: 06 October 2003, 15:07 »
Have you checked the by-pass valve between the 2 pipes that connect to the matrix, just a suggestion as this could be faulty. Run the engine for 10 minutes, then disconnect the inlet hose to the matrix , restart the engine and see if there is a good flow of coolant.
Offline Rob
« Reply #4 on: 08 October 2003, 12:38 »
My car used to do the same as such but would probaly take a bit longer to blow cold.
after a while of head scratching a mechanic friend of mine noticed the rubber pipe from the metal pipe attached to engine going to the heater matrix (hope that made sense) was kinked,  it should have a bend anyway but not like this was, ?6 from vag and it seems to have been cured,
Definately worth a look at
1990 8v gti
Offline SHAKSTER
« Reply #5 on: 09 October 2003, 16:12 »
I worked it out... it was the heater matrix by - pass valve. I get loads of heat now... theres a kink in the rubber pipe which i will sort out.. thanks mate
golfvr6
« Reply #6 on: 10 October 2003, 00:21 »
Right again then  ;)
