Author Topic: Bcm module for led rear lights  (Read 8392 times)
Offline ravydav
« on: 25 September 2012, 11:41 »
I have recently purchased rear R leds (Much thanks to KennyGti) and what a difference, looks miles better but after playing around with vag-com the warning lights for lights will not code, i think it's because is an 09 car. Therefore i'm looking to get a new Bcm, i'm wondering if anyone has the exact part number for the Bcm I am after. Car has xenons as standard, rear leds and I will be picking up vw rear led number plate lights shortly. If anyone has the part number it will be a great help
Offline Wabbit
Re: Bcm module for led rear lights
« Reply #1 on: 25 September 2012, 22:39 »
I have just coded my 2009 bcm for the led rears. My car also have xenons and I thought all 2009 cars with factory xenons can code 04 in byte 18
Golf GTD MK6 Zenons, Leather, Dynamic Chasis Control, Park Assist, RNS510. Golf GTi Mk6 DSG, Leather. Golf Mk2 G60 Edition One, Recaro's, e/w, c/l, ABS
Jimmymature
« Reply #2 on: 25 September 2012, 22:55 »
I replaced my BCM for Rear LEDs
The BCM part number was 1K0937087D.
Cheers,
Jim
Offline ravydav
« Reply #3 on: 26 September 2012, 13:13 »
I have tried to change to 04 in byte 18 but does not work, Is your car 09 or 59?
Offline EyeballPaul
« Reply #4 on: 26 September 2012, 13:53 »
I fitted R rear led's to my 09 GTI didnt need a new BCM, from what i read a long time ago if VW upgrade the software you wont need to change the BCM, but they are very reluctant to do it.
Luckily my car was in the dealers the week before i fitted the lights as the alarm kept going off and they had to do some sort of software update. Steve P checked the coding and though it was something to do with the VW software upgrade.
Offline Wabbit
« Reply #5 on: 26 September 2012, 20:29 »
Mine is an early 59. I will connect my laptop later and get the BCM number for you
Offline mustard
  • Mk7 R
« Reply #6 on: 26 September 2012, 21:49 »
There's a thread on VW Votex site which has lots of info on coding the rear LEDS, I used this to get mine coded. It's a 2010 (model and I had to use 15 at byte 18 to get the lights working properly.
See thread - http://forums.vwvortex.com/showthread.php?4898893-LED-tail-Install-with-or-without-Rear-Fog.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #7 on: 27 September 2012, 08:00 »
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
Offline KennyGTI
« Reply #8 on: 28 September 2012, 19:08 »
Any joy with this mate?
APR Stage 2+
Offline ravydav
« Reply #9 on: 28 September 2012, 22:35 »
Away at work the now so just trying to sound people out, as you know from when down the road can't use vag-com too much as battery dying, getting that looked at when get home and friend who works at vw looking into possible software update to BCM. Need to physically look at BCM to get exact part number and take it from there, i've seen it done on other 09 cars no problem so here's hoping a bit of fettling and it will come good. How's the new wheels? Can't view pictures on computers out here but i'm sure it looks sweet, maybe i'm biased but red is definetly the best colour.
