Golf mk5
Polar FIS fitting?
Topic: Polar FIS fitting? (Read 2366 times)
Adam
Forum addict
Polar FIS fitting?
24 September 2012, 16:17 »
I have searched all over the place for the fitting/costs and parts to do the this.
Anyone got some information on this?
Adam
Down Hill From Here.
Hurdy
Serious forum addict
Re: Polar FIS fitting?
24 September 2012, 19:49 »
I'd suspect it will come with full fitting instructions. It only needs a plug in point and power supply iirc.
Seat Leon Cupra Black
290
DSG
bacillus
24 September 2012, 22:28 »
Unless things have changed, the Polar only comes with a split cable for connecting to the canbus gateway and the polar unit. There are no instructions sent with it but you can download it.
It's actually very easy to fit depending on where your canbus gateway is located so you should be able to fit it yourself. atm you'll have to order one from polar themselves as Richard the UK agent at Volksdiagnostics no longer deals with them.
http://www.polarteam.net/
hth
Without traction power is nothing!
bacillus
24 September 2012, 22:30 »
btw you must have a highline mfd for the polar display.
maxitrol
01 October 2012, 00:47 »
my polar unit fitted under the dash above the pedals--but some fit on the later ones behind the ash tray
Golf mk5
Polar FIS fitting?
