Author Topic: notchy steering  (Read 1339 times)
Offline cutandsnip
notchy steering
« on: 24 September 2012, 15:06 »
hi i have an r reg 8 valve gti! lowered to the max really. since i bought it few weeks ago its pulled to the left a bit but not bad. got in it today and steering really notchy and now worried to drive it in case do any damage but have no idea what it is.  had a blow out on saturday so dunno if that doone any damage. plenty of power steering fluid in.
any suggestions as to what it might be please?
thanks
Offline spikenipple
Re: notchy steering
« Reply #1 on: 24 September 2012, 15:07 »
Could be your power steering belt needs tightening/replacing.
Offline cutandsnip
Re: notchy steering
« Reply #2 on: 24 September 2012, 15:15 »
thanks is that an easy job and expensive do you know?
Offline spikenipple
Re: notchy steering
« Reply #3 on: 24 September 2012, 15:37 »
It's a pretty simple job, get the right hand front of the car up securely on an axle stand, remove the wheel and take off the belt cover that clips on underneath. Gently loosen the 3 bolts holding the power steering pump on, then with a spanner ready to retighten one of the pump bolts, turn the "geared" looking bolt to tighten up the belt and nip up the pump bolt. Once you're happy with the tension, do the pump bolts back up, put the cover back on and stick your wheel back on.
If you need to replace the belt, the process as above still applies but you'll just need to swap the old belt for the new by releasing the belt tension first, pull off old belt, put on new belt making sure it's located on the pulleys properly and tension it.
A new belt will cost you about £4.
Offline cutandsnip
Re: notchy steering
« Reply #4 on: 24 September 2012, 15:58 »
thank you! your a star! will give this a go as soon as possible and update
thanks again
