Author Topic: Need help on part numbers please? :/  (Read 2385 times)
Offline markallen
  • AUM 1.8 20v Turbo 150bhp for now ;)
« on: 24 September 2012, 12:34 »
Hi my engine management light came on so a friend erased the codes then after a test drive it came back with the following codes. Just wondered if anyone knows the part numbers for these? It's a Mk4 1.8T
P1340 cam shaft position sensor
P0571 brake switch
P0327 knock sensor signal too low
P0501 speed sensor
Thanks for any information given :)
Golf Mk4 GTi Turbo, R32 front bumper, Lowered on ProSport Coilovers, Bora illuminated vents, Armrest, Heko wind deflectors, Aluminium vinyl trim.
Soon to be added, FMIC, 3" exhaust, Remap..oh and new turbo :(
Offline Lurky
Re: Need help on part numbers please? :/
« Reply #1 on: 24 September 2012, 12:57 »
Reg?
Offline markallen
« Reply #2 on: 24 September 2012, 13:18 »
Offline Lurky
« Reply #3 on: 24 September 2012, 13:41 »
knock sensor- VE369005-Oval block connector without lead
knock sensor - VE369026-Chassis 1JY000001 on Brown oval connector with lead
cam sensor-VE363182
all above are cambiare numbers
will try find the others
Offline markallen
« Reply #4 on: 24 September 2012, 13:54 »
Thanks mate really appreciate it. cambiare numbers??? :/
Offline Lurky
« Reply #5 on: 24 September 2012, 14:23 »
cambiares the maker of the part any motor factor should be able to crossover the part numbers to what ever make they use
http://www.cambiare-ve.com/search-vehicle.asp?orderby=product_code&orderdirection=ASC&make=Volkswagen&model=Golf&engine=1.8&the_reg=2000&product_type=Brake+Light+Switch
Offline markallen
« Reply #6 on: 24 September 2012, 14:29 »
You my are my hero :grin: if I ever bump into you on a night out there's a beer for you  :laugh:
Offline Chris.
« Reply #7 on: 24 September 2012, 14:29 »
Before going and replacing parts...are they actually at fault?
Can get you the proper numbers if you want.
Click For Build Thread
Offline markallen
« Reply #8 on: 24 September 2012, 14:56 »
They came up on a machine plugged into the pink ecu slot near the ash tray?
Offline Chris.
« Reply #9 on: 24 September 2012, 15:00 »
They are your fault code numbers.
Put them into the search here and find out why they were triggered
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
