Author Topic: Canon dummy. Help please  (Read 3322 times)
Offline tweed
« on: 24 September 2012, 10:49 »
I've decided I want a canon. Always liked taking pictures etc.
But I haven't a clue what's good and what's not. I will only get a used one to start. Was going to bid on a canon 1100d dlsr just now, but didn't as I wasn't sure and it ended at £230 with 18-55mm and 28-80mm
So could I have some advise on what to look out for please. So I can keep an eye on eBay and get a good deal when I see one.
Thank you!!
Offline Winso
Re: Canon dummy. Help please
« Reply #1 on: 24 September 2012, 11:02 »
Canon - good choice
Buying second hand - good choice
What sort of budget do you have to play with?
Offline tweed
« Reply #2 on: 24 September 2012, 11:13 »
I don't want spend any more than £500 to start.
Was hoping around £300. But don't know what to get
Offline DubFan
« Reply #3 on: 24 September 2012, 12:12 »
£500 will get you a very decent S/H Canon.
You don't have to look on just ebay either.
Don't be fooled into thinking the ebay prices are the best. Particularly with Canon and Nikon gear the prices get pushed up during the auctions so the prices aren't that great.
Also look at the new deals on Jessops and Warehouse Express.
Warehouse Express actually have the Canon 1100D with 18-55mm lens for £349. So you could just get a new one.
http://www.wexphotographic.com/buy-canon-eos-1100d-digital-slr-camera-with-18-55mm-is-ii-lens/p1523930
Here's a Canon 1100D with 18-55mm lens £280 from a shop:
http://www.lcegroup.co.uk/Used/Canon-EOS-1100D-+-18-55_61464.html
The you could add a zoom lens
Canon 75-300mm for £80
http://www.lcegroup.co.uk/Used/Canon-75-300mm-USM-III_61465.html
and a prime if you wanted.
Canon 50mm f1.8 for £80
http://www.lcegroup.co.uk/Used/Canon-EF-50MM-F1.8-II_60922.html
All that ^ for £440
Or swap the Canon 50mm for Canon 28mm f2.8 for £50 more
http://www.lcegroup.co.uk/Used/Canon-28mm-F2.8-A/F_61042.html
Or you could swap for a Canon 450D which is the same price as the 1100D but a slightly better camera:
http://www.lcegroup.co.uk/Used/Canon-450D-+-18-55_61427.html
Or even a 40D (up another notch of quality) for £300 (but without lens)
http://www.lcegroup.co.uk/Used/Canon-**SUMMER-SALE**40D-BODY_51657.html
Offline tweed
« Reply #4 on: 24 September 2012, 12:21 »
Wow  :cool:
Best reply I've ever had. Huge help thank you.
Someone told me to get a canon 600d. Is that better or something?
Offline tweed
« Reply #5 on: 24 September 2012, 12:35 »
Really liking that jessops site  :smiley:
Offline stealthwolf
« Reply #6 on: 24 September 2012, 13:04 »
I always advise two things:
- look on dpreview.com for camera reviews - helps you understand pros/cons of cameras
- go to the shop and try them out. You may not be able to try older cameras but you should be able to get a good idea of the feel of a camera and whether it feels natural to use/hold.
Offline DubFan
« Reply #7 on: 24 September 2012, 13:39 »
You do really need to go to a shop to try a camera.
Jessops will probably have a store near you and will have the latest Canon DSLRs in for you to try.
A Canon 600D is good, but it's the current model so will be more expensive.
Canon model numbers are easy to understand:
1100D and 1000D are the budget models.
400, 500, 600D are mid range.
450, 550, 650D are slightly higher
40D, 50D, 60D are high mid range/almost semi pro.
7D - semi pro/low pro model
6D - brand new full frame but small Pro model
5D (Mk3 is current model) is the pro standard.
1D/1DS/1DX - top of the range Pro models.
If the number (of the mid range) model starts with a 4, it's older, it it starts with a 5 it's about 2yrs old, if it starts with a 6, it's the current model.
So a 600D is the current model in the mid range. The 400 is the older equivalent (Horney has one) but it's still decent, although it doesn't do video. Most of the newer models will do video.
Looking at DPReview.com is good for gauging specs, but you really need to feel what they're like in your hand and try out things like the menus and changing modes, etc.
Here's a spec comparison for a 600D, 550D and the 1100D:
http://www.dpreview.com/products/compare/side-by-side?products=canon_eos600d&products=canon_eos550d&products=canon_eos1100d&sortDir=ascending
Offline tweed
« Reply #8 on: 24 September 2012, 14:10 »
thank you very much, I feel I've got enough info now to work out what I want and what's worth the money.
thank you
Offline Diamond Hell
  • Opinions я Us
« Reply #9 on: 24 September 2012, 14:18 »
Here's another option for you - Mifsuds.  Someone I know recently bought a 30D from there recently, it went tits, she returned it and they sent her a 40D as a replacement.
Here's their current list of secondhand bodies:
http://mifsuds.com/acatalog/Used_Canon_EOS_Bodies.html
and here's their list of current secondhand lenses:
http://mifsuds.com/acatalog/Used_Canon_EOS_Lenses.html
I'd choose your body depending on your requirements, maybe a 40D and then get on the phone to them to see what deal they'll do you for a body and a walk-around lens - something like a Sigma 18-50mm F2.8 EX DC.
