Author Topic: 8valve running rich.  (Read 7938 times)
Offline gizago
« on: 23 September 2012, 17:41 »
My mk3 8valve is running rich- any common faults that cause this?? It idles fine, drives fine, but smells strongly of petrol. There are no leaks etc anywhere, its definitely just running rich. Is this something that can be adjusted out, or is it likely to be a sensor playing up??
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: 8valve running rich.
« Reply #1 on: 23 September 2012, 17:55 »
Could well be the hall sensor on the distributor needing set up. Best to get a code reader or vagcom hooked upto it.
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 23 September 2012, 18:09 »
I would change the temp sensor
Offline gizago
« Reply #3 on: 23 September 2012, 18:31 »
Ive had a fault code reader on it to try and trace an intermittent fault which turned out to be the crank sensor, which ive now replaced. I'll check back over the codes and put them up here.
I did wonder about that, but when the blue temp sensor went on my mk2 it was different symptoms, wouldnt idle, cut out if you came off the power quickly etc. Worth a try though.
Cheers guys.
Offline gizago
« Reply #4 on: 23 September 2012, 18:39 »
Fault codes it had were-
65535:- (control module defective faulty static)
00513:- (engine speed sensor G28 signal outside tolerance intermittent)
00515:- (camshaft position sensor G40 signal outside tolerance intermittent)
00523:- (intake air temp sensor G42 open circuit/short circuit to B+ intermittent)
If anyone can shed any light on any of those.....
Since then I've fitted a new crank sensor and swapped the maf for a different one. If these re-set the same as mk2 digi's then ive resert it too. (ie revved it to over 3k 3 times when stationery)
Offline Gti_Jamo
« Reply #5 on: 23 September 2012, 18:51 »
Camshaft position sensor (g40) is the hall sensor on the side of the distributor but not sure what would cause it be intermittent, could be faulty or the wires going to it have become brittle which is a coomon issue. Mine was out of tolerance when I rebuilt my engine and it was running so rich my down pipes were glowing red hot. Not usre on what the rest of the codes mean.
Offline gizago
« Reply #6 on: 23 September 2012, 19:02 »
Excellent, hopefully a new one will sort it then. Its been reluctant to start from cold too, spinning over but not firing which is probably caused by the same sensor I guess. Cheers mate, much appreciated.
« Last Edit: 23 September 2012, 19:14 by gizago »
Offline tweed
« Reply #7 on: 24 September 2012, 03:57 »
They wouldn't do that if its rich. To much fuel and it will cool the motor. So it would have been very lean!!
Offline Gti_Jamo
« Reply #8 on: 24 September 2012, 11:00 »
Was definately running rich like, the smell of fuel was horrific and popping and banging.
Offline Metallix
« Reply #9 on: 24 September 2012, 11:38 »
Not saying it is in this case, but very lean can seem like very rich due to lean misfire not burning the fuel = sends unburnt fuel into the exhaust
