Golf mk4
Wazzzer
If this is right, we could use blowoff valves?!
Topic: If this is right, we could use blowoff valves?! (Read 1370 times)
Nino
22 September 2012, 21:58 »
I sumbled across this tonight while doing alot of research (as you do) Now to my understanding I always thought that Our engines (1.8T's) had to have a Diverter valve? I have been told this many many times by all sorts of people, but Watch this video and it shows they run a mk4 golf turbo (it has been modded) on the standard DV, an uprated DV and then a blow off valve and well... see your selfs... Btw at about 6:20 this video isnt worth watching.
http://www.youtube.com/watch?v=Z_fG_b65WiU&feature=related
Your views on this would be great, would be interesting to see what the experts think on this and please dont flame me I know there is a topic about this but I felt a new topic needed to be started purely so it wasnt missed, if MODs feel I was wrong, please merge it with the other topic and dont delete I am interested to read peoples views.
Thanks
Like my badge? Get one here:
https://www.golfgtiforum.co.uk/index.php?topic=291134.0
VW Car history
- Mk3 1.8 GL - Silver - 5 door, Mk4 1.8t - Silver - 3 door, Mk4 R32 - Black - 5 door, Mk5 GTi - Black - 5 door, Mk4 R32 - Deep Pearl Blue - 3 door, MK6 2.0 TDI - Graphite Blue - 5 door, MK7 GTD - Solid Black - 5 door.
Current
- MK6 GTi Edition 35
houston
Re: If this is right, we could use blowoff valves?!
23 September 2012, 12:42 »
agus can sometimes get away with bovs but they ecu reads the recirc values and adjusts, no recirc readings and your in limp mode
Nino
23 September 2012, 12:51 »
arhh fair enough, thou it be abit strange i suppose while conducting the test it would show fine on the read out (as shown in the video) but over time it would cause problems?
VW Car history
Current
harlemex
23 September 2012, 14:06 »
I had a baileys on my aum, and changed it back to the standard one cos i wanted more performance and i got bored with the gay noise
I could not feel any difference in performance whatsoever.
Dave_IOW
Forum addict
23 September 2012, 14:27 »
I ran a DV26 on my AGU thinking there was no difference in performance, swapped back to 007p and can safely say, I will never be putting anything non-recirc on.
Initial period after gear changes are where the difference lies.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
simon_709
GTI forum regular
23 September 2012, 15:26 »
I had a baileys on my agu when I got it, loved the sound at first but then got bored, and it never ran right under load, also when I got it re-mapped they said that the atmospheric dv is slowing my car down, changed it for a 0077p and it made the car run a lot better
My Golf GTi, RS4 reps 17", coilovers, tinted windows, De-cat and middle box removed with 3" oval back box, stage 1 Revo re map, G60 flywheel/VR6 clutch, HID kit, Forge 007p,
Chris.
Reply #6 on:
23 September 2012, 18:18 »
No 1.8T will 'get away' with a blow off valve to atmosphere. While it might work, the ECU has accounted fuelling for the air going into the engine and removing the air when throttle body is closed, your car will run rich.
Click For Build Thread
248bhp 278lbft R - Tech Powered 1.8T!! - Gone but NOT forgotton
james2
No scammers please.
Reply #7 on:
23 September 2012, 20:59 »
My car ran fine with a cheap £32 dv off ebay. I only took it off as the noise sucked, its not right. Im getting a better dumping noise off the 007 dv and my induction kit.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Nino
Reply #8 on:
23 September 2012, 22:25 »
to be fair I hear a nice dump noise with my standard one althou to hear it i must have all music off, and windows up lol
VW Car history
Current
Golf mk4
Wazzzer
