Author Topic: help needed back fire loud pop from exhaust  (Read 2514 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« on: 22 September 2012, 20:37 »
I've basically just removed the rocker cover manifolds and given th :smug:e engine a good degrease. I've changed the seal in the dizzy too. replaced the plugs, dizzy cap and arm. Put in a new lambda sensor (abf engine) went to start it and it made a very loud pop/bang from the exhaust. I've removed the dizzy and this only seems to go on one way so can't be 180 degrees out.  I did do a compression test on the engine so could it be unburnt fuel? Maybe Carbon cleaner down the inlet manifold? Should I try starting it again or am I likely to cause more damage. Any suggestions would be great!!
Re: help needed back fire loud pop from exhaust
« Reply #1 on: 22 September 2012, 21:52 »
Forgot to plug hall sender in  :embarrassed: still not firing though maybe I've fryed the coil
Offline danny_p
« Reply #2 on: 22 September 2012, 23:40 »
check the shaft in the dizzy isn't 180 degrees out  iirc that is possible
all the VW's have gone bar 1.
« Reply #3 on: 24 September 2012, 16:56 »
Cylinder 1 at tdc and arm points to number 1 so all seems good. I'm going to get a gallon of fuel as it seems pretty low just incase.  :sad:
Re: help needed back fire loud pop from exhaust will not start.
« Reply #4 on: 24 September 2012, 20:36 »
gallon of fuel has gone in still not starting   :sad:
Offline sam1990
« Reply #5 on: 24 September 2012, 21:40 »
1) did you check the gap on the new plugs?
2) is the rotor arm and dizzy cap defintly the correct ones? ie does the arm reach the contacts?
3) are you certain you have the lead order on correctly?
Offline Diamond Hell
  • Opinions я Us
« Reply #6 on: 25 September 2012, 15:32 »
Is it sparking?
« Reply #7 on: 25 September 2012, 17:38 »
yes there is a spark is the firing order 1342 on an abf?
Offline mk28vpb91
« Reply #8 on: 30 September 2012, 18:51 »
Could the cylinder be at TDC after the exhaust stroke rather than the firing stroke?
« Reply #9 on: 01 October 2012, 15:41 »
Yes it was 180 deg out I assembled the dizzy wrong. All working now
